Old 05-03-2019, 09:36 AM   #1161
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Goodbye C-12.
Todd Greene
Old 05-03-2019, 11:18 AM   #1162
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Your oil. pick up is in the wrong location...
Do yourself a favor and give me a call 650 922 zero 4 zero 7
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-03-2019, 11:47 AM   #1163
Nmbr1GMfan
Bob
Bob, the oil pump pickup has been moved. It's now considerably closer.
Todd Greene
Old 05-03-2019, 01:54 PM   #1164
Bob Mulry
Bob Mulry's Avatar
Originally Posted by nmbr1gmfan View Post
bob, the oil pump pickup has been moved. It's now considerably closer.
call me.....
Bob Mulry 7516 STK
A & M Motorsports
Old 05-03-2019, 07:32 PM   #1165
Nmbr1GMfan
call me.....
Been out of town most of the day today Bob, I'll call you tomorrow.
Todd Greene
Old 05-03-2019, 07:43 PM   #1166
Nmbr1GMfan
Had a few minutes this morning to get the lifters set up and the rockers on. I have three different lifters set up and I'm checking how they each react to oil pressure as well as differences rear to front.
Todd Greene
Old 05-03-2019, 09:35 PM   #1167
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
The oil collects in the valley and can’t drain back as fast with those extension vents. I’d get rid of them and leave the holes open for faster drain back to the pan.
Use the screw-in the back restrictors and drill the holes out a little larger and see what that looks like along with removing those extension vents.
Just my 2 cents ....
Rich Biebel
S/C 1479
Stock 147R
Old 05-04-2019, 12:19 AM   #1168
HP HUNTER
Liked 373 Times in 129 Posts
Bob
Yes
Old 05-04-2019, 10:39 AM   #1169
Nmbr1GMfan
Rich, thanks for the input. I'm worried about restrictors in the back of the block because that will restrict oil at the lobe, as well, I see a volume difference at the rocker from front to back. I'm afraid restrictors and the lower volume at the front will cause other issues. And as far as the extension vents, the engine on the stand is very slightly angled front up (but not as angled as when in the car) and the oil barely stays on the valley. I'm currently seeing all the oil running to the back of the head and straight down the rear drain holes.
Todd Greene
Old 05-04-2019, 04:17 PM   #1170
Dissident
Liked 73 Times in 36 Posts
Todd, et al,
Trivial input perhaps, albeit solidly scientific in analysis.
The oil goes in the opposite direction of vehicle acceleration, so the oil return heads to the rear very naturally. So does the oil in the sump (pan).
The angle of the liquid is a function of the acceleration in g.
1g = 45deg liquid angle
60ft times reference is something interesting to look at. Particularly where the oil pickup is placed in a drag racing vehicle!
1.4sec = 62.28deg liquid angle
1.5sec = 58.9deg liquid angle
1.6sec = 55.54deg liquid angle
All these things and more were included in the paper I sent to you a while back. These things apply to all liquids in the vehicle, including the fuel system.
Regards,
HB2
Dissident is offline   Reply With Quote
