Old 05-27-2019, 08:08 PM   #1
jrstock
Default Rear Main Seal Advice
I have observed a leak from my rear main seal. The leak is occurring ,not at the seal split line, but at the bottom 6 o'clock position. Currently using a Fel Pro 2090 seal.
I've pulled the seal and it does not look worn or damaged.
Is there a way to shim between the seal to tighten the clearance to the crank? Is there a better SBC main seal to use?
Is there a tool to locate the 2pc rear main seal adaptor on the crank that I should be using?
Any other tricks to stop the leak?
Thanks in advance for the advice.
jrstock is offline   Reply With Quote
Old 05-27-2019, 09:02 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: Rear Main Seal Advice
Put a thin film of rtv between the block and cap before installing the 2 halfs also rotate the seal splits about a 1/4 from horizontal and put a little dab there too--make sure the oil pan rail is FLAT so it's not pinching the seal and is making proper contact with the seal.maybe wipe a light film of oil on the seal to help on start up
Old 05-27-2019, 09:48 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What is the year of the block ? Is it a 2 pc or a 1 pc seal . Has the block been line honed ?
Old 05-27-2019, 09:50 PM   #4
jrstock
The block is a late model bowtie block with an adaptor to run 2 piece seal. It has been line honed.
Old 05-27-2019, 10:13 PM   #5
Alan Nyhus
Liked 800 Times in 237 Posts
One block I used had been line bored and the rear seal was leakage prone. Shortened the half of the seal that fits in the block until it fit normally. No offset and a dab of Valco aluminum silicone on the back of the seal and the parting lines.
We've seen a rash of rear main seal leaks lately with both the brown and blue seals.
"That'll never work....."
Old 05-27-2019, 11:44 PM   #6
SSDiv6
I have seen this happen a few times with the Bowtie block using the adapter. If the block has been align bored or honed, I remove the locating dowel and use the Allstar Performance rear seal adapter alignment tool P/N ALL26127.
https://allstarperformance.com/align...pter-all26127/
Old 05-28-2019, 07:12 AM   #7
carl hinkson
Liked 18 Times in 10 Posts
2090 seal is not a good number
carl hinkson is offline   Reply With Quote
Old 05-28-2019, 08:39 AM   #8
Nmbr1GMfan
My issue was the crankshaft wasn't perfect where the seal would normally ride, this seal fixed it. Fel-Pro BS 11829-1 Rubber 2 piece offset double lip seal
Todd Greene
Old 05-28-2019, 10:39 AM   #9
FED 387
I think he means 2909
Old 05-28-2019, 11:46 AM   #10
carl hinkson
That does not work with a 400 main
