Old 05-30-2019, 01:43 PM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Fuel in intake
Has anyone seen this ? I have a 383 mopar stock engine and have been getting fuel fouled spark plugs and I see fuel on the plenum floor of the intake. It's dual plane intake, fuel is on both sides. I've been working on the carb (holley) thinking too much of the transfer slot is exposed. The heat passage is blocked, so I'm wondering is the fuel puddling up because I've blocked the heat passage which not letting the fuel atomize ? I thought I had fuel in the oil,but I had it analyzed and they didn't detect anything. I was thinking about putting hotter plugs in it and maybe that would burn the fuel off. any experience ??
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 05-30-2019, 01:59 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Fuel in intake
Overly rich or weak-marginal ignition system ---is it every plug or just one?
Old 05-30-2019, 02:10 PM   #3
GallopinGhost
Ignition should be good. Everything new, msd dist., daytona sensors box. I've checked wire resistance from inside of cap to plug, all good.
it's 6 out of 8 plugs, I'm thinking cyl. to cyl distribution of this intake is pretty bad. Once I get to fine tuning it, pretty sure it will have staggered jetting.
don't think its rich basically. fuel mixture screws are adjusted to rpm/manifold vacuum
Brian Carpenter
Stock 1358
Old 05-31-2019, 07:38 AM   #4
Liked 11,006 Times in 2,263 Posts
Pull carb off and keep the fuel line hooked up. Then hold it level and have someone turn on fuel pump and see where the fuel is leaking. It maybe a gasket that is allowing fuel to drain through a vacuum port into the intake.
Old 05-31-2019, 08:58 AM   #5
GallopinGhost
I've tried that Larry, not a drop. fuel pressure at 6#. When the engine is running, I can look down and nothing is coming out of the boosters. But when I take the carb off, the top of the base gasket is always wet. It's a 4 hole gasket to match intake. I'm missing something..
Brian Carpenter
Stock 1358
Old 05-31-2019, 10:48 AM   #6
FED 387
What kind of accelerator pump do you have-did u check the vacuum plug too--try another carb see if it still persists
Old 05-31-2019, 12:05 PM   #7
Alan Nyhus
Liked 800 Times in 237 Posts
What's your power valve situation?
"That'll never work....."
Old 05-31-2019, 12:38 PM   #8
FED 387
I meant power valve not vacuum plug
Old 05-31-2019, 01:40 PM   #9
GallopinGhost
I don't have another good carb to try. Accelerator pump is 30cc, PV is 2.5. This problem happens after just idling. I have a plug for the PV, yet to try it though. I guess I'll try to map out all the passages next. Also will post some pics.
ID:	50060   Click image for larger version
ID:	50061   Click image for larger version
Brian Carpenter
Stock 1358
Old 05-31-2019, 01:52 PM   #10
NORMAN BARNARD
Liked 2 Times in 2 Posts
What is the list number of the holley carb.???
NORMAN BARNARD is offline   Reply With Quote
