Old 06-02-2019, 11:22 AM   #1221
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Greg Reimer 7376 View Post
The NHRA legal replacement part number for a 4 inch bore SBC with a 2 piece rear main seal is 31161111. Summit shows it in their catalog for $1718.26 on page 124. That's the March-April catalog.
That will for sure be my next one.
Todd Greene
Old 06-02-2019, 04:08 PM   #1222
Nmbr1GMfan
Today we pulled the redneck A/C from the rafters for what will surely be another hot summer. Started pulling Racepak bits out of the boxes and found a spot for the logger just for something to do. I'll update on the block situation tomorrow, if I can pick one up local I'll have a plan in place pretty quick.
Todd Greene
Old 06-03-2019, 12:22 AM   #1223
Jody Lang
Liked 92 Times in 29 Posts
So was the #3 main cap broke?
Jody Lang is offline   Reply With Quote
Old 06-03-2019, 07:55 AM   #1224
Nmbr1GMfan
If something is in fact wrong with the block, I cannot see it. Something is definitely wrong, but as usual I can't find a smoking gun.
Todd Greene
Old 06-03-2019, 01:31 PM   #1225
Jody Lang
Definitely frustrating to say the least.
Great thread and good luck getting it back on the track!
Old 06-03-2019, 04:41 PM   #1226
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Originally Posted by Rich Biebel View Post
Todd if your going to stick with a stock block I would look for a 4 bolt with nodular caps.
Not trying to go off topic however since so many knowledgeable / helpful people have responded to this thread, how does one identify a production 4 bolt block w/ nodular caps ?
Old 06-03-2019, 07:21 PM   #1227
Nmbr1GMfan
The caps with 2482 cast into them are nodular as I'm told.
Todd Greene
Old 06-03-2019, 07:39 PM   #1228
Nmbr1GMfan
Picked up a block today, .030 over newly machined with new freeze plugs and cam bearings installed, but looks as if it's been sitting in a shop for some time. Here's the plan, about an hour away there's a guy that I know of that has a strip tank for car bodies, it TOTALLY strips paint and rust from steel so I've pulled all plugs and cam bearings out of this thing and I'll drop it to him tomorrow to see how it works removing rust from blocks. Hopefully cleaning the water jackets so it's ready for hardblok on the inside and super clean everywhere else. some probably think I'm crazy for using a stock block, but I promise I have a plan. This will be a backup engine (if it ever runs) to a real nice one later. Nothing special here, certainly no worse than the 2-bolt we had.
Todd Greene
Old 06-03-2019, 07:53 PM   #1229
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Yes Todd is correct. Three center 4 bolt caps have 2482 cast into them and usually N also. Nodular iron is still cast but better than plain grey iron.
Some caps are really pretty weak.
I’ve taken engines apart with a broken center main cap and the engine was still running !
Rich Biebel
S/C 1479
Stock 147R
Old 06-03-2019, 08:29 PM   #1230
Tim H
Tim H's Avatar
Ok, and the caps with the #3412 cast on them are the regular,less desirable type.
