Old 06-03-2019, 08:34 PM   #1231
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Tim H View Post
Ok, and the caps with the #3412 cast on them are the regular,less desirable type.
Those are the standard "grey iron" cap.
Todd Greene
Old 06-03-2019, 09:34 PM   #1232
FED 387
Liked 335 Times in 182 Posts
Todd check yet PM Dick
Old 06-04-2019, 07:41 AM   #1233
Nmbr1GMfan
I saw that about the desiccant plugs? My PMs are wacky sometimes and I cannot respond but I did see this Thanks.
Todd Greene
Old 06-04-2019, 03:51 PM   #1234
Nmbr1GMfan
Dropped the block off today, it'll most likely be a week before I get it back to start machine work.
Todd Greene
Old 06-04-2019, 11:46 PM   #1235
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
Seems to me that aftermarket steel main caps are available someplace for 4 bolt main 350's,must be better than the originals.Just trying to remember where I saw them.
Old 06-05-2019, 08:38 AM   #1236
Nmbr1GMfan
They're everywhere, lots of aftermarket ones for sale.
Todd Greene
Old 06-05-2019, 12:13 PM   #1237
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Why put money into a questionable foundation.Cleaning block, Filling block, installing main caps etc.
Old 06-05-2019, 02:51 PM   #1238
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
30 years ago we sonic tested and Brinell hardness tested all small blocks.
The range from soft to hard was pretty significant.....and a hard block would easily make more power.
Ideal was hard and decently thick cylinder walls.....
.060 over was a lot.....
Cylinder walls were just about always not consistant
Core shift could be ridiculous
You can usually see the cam being off center by the flat machined surface at the face of the cam hole...not concentric
I had one engine I built at home that was so far off center it was silly
The crank and cam centerline were way off center.
So bad I had to get different rods. It was a 383 and I could not get clearance on one side for the rods to block even after grinding and the other side went right by with plenty of clearance.....
Aftermarket and even Bowtie blocks are far better....
Just sayin!!!
Rich Biebel
S/C 1479
Stock 147R
Old 06-05-2019, 03:00 PM   #1239
Hacksaw
Liked 314 Times in 177 Posts
Put the money you will spend on main caps and the labor to fit them towards a Bow-Tie or Dart block.
Old 06-05-2019, 05:51 PM   #1240
Nmbr1GMfan
I honestly don't see this as being questionable. How is a 400hp stock block an issue?
Todd Greene
