Old 06-04-2019, 11:19 AM   #1
2021STK
Liked 17 Times in 14 Posts
Default Need help restoring Super Trick and Motor Wheel finish
Need a little help, I want to duplicate the original spun finish on the early Cragar Super Trick and Motor Wheel Flea and Fly wheels for a nostalgia drag car. The wheels have the normal wear, stains and scuffs of 49 year old race wheel. Doesn't need to be a full restoration, just trying to make them a little more presentable.
Thanks in advance
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 06-04-2019, 12:02 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Need help restoring Super Trick and Motor Wheel finish
I would try ScotchBrite in the original direction
Old 06-04-2019, 12:24 PM   #3
Jody Lang
Liked 92 Times in 29 Posts
An acid type wheel cleaner works well. Wheel off laying flat and let it soak for a bit. Maybe scrub with a brush. Might not look brand new but it works good.
I think scotchbrite might smooth the surface.
Jody Lang is offline   Reply With Quote
Old 06-04-2019, 12:57 PM   #4
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Depending on how particular you are and how much money you want to spend there are two national wheel companies who do wheel restoration one being ALLOY WHEEL REPAIR and the other is TURBAX. Most insurance companies use these wheel repair services for insurance claims. I have had experience with both companies and both do excellent work.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 06-04-2019, 07:02 PM   #5
Frank Castros
Liked 2,793 Times in 983 Posts
Original Never Dull in the blue can, at Walmart. I used it for years on my Centerilnes and received many compliments.
Old 06-04-2019, 08:31 PM   #6
I think we're trying to duplicate the factory spun, machined finish..ala Moon discs, for the senior citizens here.
Old 06-04-2019, 09:05 PM   #7
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
The MW flys are magnesium and are hard to clean,the ST's are alum.How dull are the fly's,you may have to get them polished at a shop.Also they have a red foam like center filler,is it still solid not cracked?.A buddy had a pair about 20 yrs.ago and they were very dull (grey) and soiled.He had them polished and then clear coated looked like new.Sold them about 10 yrs later with center caps for big $$. Perfect wheel for an early to mid 70's drag car resto. gsa612
Old 06-05-2019, 08:20 AM   #8
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
If you are trying to maintain/keep the original grey anodized finish on a super trick be gentle,hot water with the lightest duty SOS pads following the factory spun finish.
But not an acid style cleaner you would use on a Centerline as they do not have a coating like the Cragar
You may want to remove the bolts for best results.
chopperloco is offline   Reply With Quote
Old 06-06-2019, 11:02 AM   #9
2021STK
Mark you are right on, I'm pretty sure the original finish was due to the metal spinning process used during production.
My front ST's are in really good shape so I just use a damp towel on them. The rears I want to use need help. Planning to mount a spare outer rim on a lathe, spin it slowly and drag a stiff wire brush or an abrasive to duplicate the original sheen finish, not trying to polish them. I have one new in box 15X14, 7" BS ST I can use to compare the finish with and would love to find another!
The MW Fleas(magnesium) were polished at some point in time, now a fuzzy dark gray. One has the red filler in good shape the other does not. Rear Flys(aluminum) one set polished and the other set spun spun needing some help.
Thanks again
Dave Outten
2222 S/SS/SST/SG/HR
Old 06-07-2019, 01:08 PM   #10
Dirk Olson
Liked 172 Times in 46 Posts
Ask Doug Engels from SD has done two cars with those wheels
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
