Old 06-07-2019, 09:20 PM   #11
2021STK
Liked 17 Times in 14 Posts
Default Re: Need help restoring Super Trick and Motor Wheel finish
Thanks Dirk! You wouldn't happen to have his contact info you could PM to me?
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 06-09-2019, 06:42 PM   #12
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
I've spoken with Doug in the past,his rears were new old stock he found,the fronts are new Bogarts (brushed) ,with Super Trick caps...
chopperloco is offline   Reply With Quote
Old 06-12-2019, 02:51 PM   #13
2021STK
I stumbled onto a Ytube video today of the Moon Equip. Co. metal spinning their tanks and they refined the surface with sandpaper to give a satin finish.
Sounds like a good place to start on the Super Tricks, now all I need is a big lathe.
Thanks for all the suggestions and help.
Dave Outten
2222 S/SS/SST/SG/HR
Old 06-12-2019, 04:15 PM   #14
Hacksaw
Liked 315 Times in 178 Posts
In the 70's, I took my Super Tricks apart and bolted the outer to my Chrysler New Yorker"s rear hub. Had the fronts blocked and the other wheel on the ground. Spun her up and sanded my finger tips off. Just have to do the center areas by hand.
Old 06-12-2019, 06:11 PM   #15
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Ah yes,the "polish lathe"...lol. gsa612ski
Old 06-14-2019, 08:20 AM   #16
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
I work in a refinery and there are pipe cutting and threading tools used for small bore pipe there. They are open on one end so its easy to chuck the wheel in. Do this and clean all the oil and dirt first. Then use 320 grit or finer and let the machine turn as you "sand" it. You can control the finish because these machines turn slow. Did all four of mine and they looked brand new! Crager Super Tricks... With the clear coating gone, they are harder to keep looking that way but they can be coated again.
Lee.
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
