Old 06-13-2019, 07:13 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Turbo 200
New to the 200 metric world for super stocker. Bought a used unit...how much fluid is required for deep pan? Came with a lokar dip stick but not sure if it's accurate. Thanks.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 06-13-2019, 09:12 PM   #2
HR9121
HR9121's Avatar
Default Re: Turbo 200
Ed I've always been told 6 3/4 to 7 quarts but I would probably pull the pan with the dipstick in so you can get an accurate measurement. Paul at Turbo Action always recommend the full mark be 5/16 inch below the bottom of the transmission where the pan bolts on.
James Williamson
W200 J/SA. SS/JA
Old 06-14-2019, 02:27 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Go to turboaction.com,on the left side of the page click on technical tips then click on tip #12.It will give you the info on fluid levels on a M200..gsa612
Old 06-14-2019, 08:50 PM   #4
Ed McLawhorn Jr.
Thanks guys.
Old 06-14-2019, 10:00 PM   #5
gsa612
gsa612's Avatar
What does the trans. have for venting,a long hose to the top of the bell?.When I first fill mine I just go a hair above add then get the trans. temp.to about 160 and check it.On mine it comes up to just under full.Proper venting and fluid level is important or you'll have atf all over.Do you know who built the trans?. gsa612
Old 06-15-2019, 10:43 AM   #6
Ed McLawhorn Jr.
Yes, it has the vent tube up past bell. I have attached it to the dip tube. It was originally built by mccay sp? but sepanek refreshed it last time.
Old 06-15-2019, 11:02 AM   #7
FED 387
Liked 335 Times in 182 Posts
Ed I would contact Scott Mcclay directly and ask his advice 661-822-8209 phone number he is in
California so remember the time difference
Old 06-15-2019, 11:02 AM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Its better to run a vent hose back toward the transmission cross member . Running it up the dipstick tube could allow any fluid leakage or spray to land on the headers which could have a bad effect . That's why most companies have a sealed locking dipstick tube .
Old 06-15-2019, 02:57 PM   #9
Painter
Liked 162 Times in 45 Posts
I will have to disagree on this. If you run the vent hose forward and upward into a small vented container then what fluid is in the tube has a ban even to drain back into the trans! Jazz makes a small plastic one pint container with a drain and vent filter that doesn’t weigh much or take up much space on the firewall. Running the vent hose back is inviting not only a mess on the underside of the car but disaster if the trans is overfilled the fluid gets on the tires.
Painter is offline   Reply With Quote
