Old 07-02-2019, 06:15 PM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Stocker carb, removing choke plate ok ?
I don't see anything in the rule book on this, but in the accepted products document there's a section called carb notes, and it says it's ok. Although the way the documents reads, it's not super clear what it applies to.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 07-02-2019, 07:07 PM   #2
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Default Re: Stocker carb, removing choke plate ok ?
The choke plate has to stay, but can be open and inoperative.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
Old 07-02-2019, 07:11 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Carb notes apply to carburetors used in Comp and SS/Modified, not regular Super Stock or Stock.
Old 07-02-2019, 09:12 PM   #4
GallopinGhost
page 62 does mention Stock, SS, etc. But the context is replacement carbs, so probably doesn't include alternate carbs..........
Brian Carpenter
Stock 1358
Old 07-02-2019, 10:50 PM   #5
e vassar
Liked 281 Times in 110 Posts
Take it off and put it back on if they tell you to.
Old 07-03-2019, 12:19 AM   #6
Crew Chief
Liked 10 Times in 6 Posts
Just be sure you keep the choke plate and shaft in the tool box in your trailer because you will have to put it back on someday.
Crew Chief is offline   Reply With Quote
Old 07-03-2019, 07:27 AM   #7
GallopinGhost
10-4
Brian Carpenter
Stock 1358
Old 07-03-2019, 12:12 PM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
In tear down, if I was a Tech guy and found a car running without the choke plate, my recommendation would be for a 1 year suspension due to an intentional violation of the rules.
Bob Mulry 7516 STK
A & M Motorsports
Old 07-03-2019, 01:03 PM   #9
I doubt if found during a spot check after winning a 3rd round heads-up, that they would allow you to put it back on.
As Bob said,...maybe in a year or so.
Old 07-03-2019, 02:29 PM   #10
GallopinGhost
So I get where the rule book does not allow removing the choke. The reason I started this thread is because it looks to me if you are allowed a "replacement" carb, i.e. edelbrock, or quickfuel, which seems to be legal in stock, it spells out in the carb notes what mods you can do, and that includes removing the choke. That doesn't make sense to me, but that is what I see. Maybe I'm reading it wrong.
Name:	page 62 (2).jpg
ID:	50590   Click image for larger version
Name:	page 64 (2).jpg
Brian Carpenter
Stock 1358
