#11 |
Liked 320 Times in 102 Posts
Here it is...……
From 2019 NHRA Rulebook Section 11A, page 3 CARBURETOR Must be correct year, make, and model specified for car’s engine; fuel or air bleed passages may be resized. Drilling idle holes in primary throttle blades permitted. Other modifications prohibited. Sandblasting, grinding, flash removal, dry film coating, or any other modification to carburetors prohibited. Replacement carburetors permitted provided they are same model, type, throttle bore, and venturi size. Computer carburetors use latest model non-computer carb for engine application. It also doesn't say that you can poke a sharp stick in your eye.... Unless it states that it's allowed, it isn't... PS: This is also the rule for Super Stock....
#12 |
Liked 2 Times in 2 Posts
It's certainly in black and white. i still do not agree with it "stock class" should have a choke plate in the carb. thats how they came stock.....
#13 |
Liked 7,866 Times in 1,750 Posts
What you are looking at are the "rules" for SS/Truck, FWD SS and Super mod and Comp. Go back and read the WHOLE thing .....SLOWLY.....
#14 |
Liked 10,966 Times in 2,260 Posts
Other modifications prohibited. Third sentence in stock carburetors in current rule book. For me a 50 cc Reo pump would be great but not allowed, a metering plate change in the end carbs would be great, but not allowed. An inch spacer would be great but not...........
#15 |
Liked 21 Times in 13 Posts
I have learned something today. There are some threads that should have never been started.
I agree the rule book is clear that you can't remove the choke plate in stock. I was merely trying to understand the carb section in the accepted products document The way I read it, the carb notes that start on page 62, that for stock, SS, SSGT, SSGT truck various mods are listed, including removing the choke plate. Looking at the rule book for SS and Comp, I don't see anything on carbs at all except they do refer you back to lower classes. In any event my carb will have the choke plate intact, and if any of the nhra tech auxiliary would like to come by at a divisional, please do.
Brian Carpenter Stock 1358 |
#16 |
From the 2019 NHRA Rulebook....
Another key to understanding the NHRA Rulebook is that certain classes “build” from another. When the Rulebook states “Requirements and Specifications for … are the same as those for ...” you must read the referenced section first. If after reading the Rulebook you still have questions, consult page xiv for hours and phone numbers where tech personnel may be reached. These phone lines are extremely busy, so prepare your questions in advance. Remember, it is your responsibility to follow the standards in this Rulebook that pertain to your vehicle AND SECTION 12 SUPER STOCK Requirements and specifications for all Super Stock categories are the same as those for Stock Cars - Section 10A - with the following exceptions: PS: You got some bad and incorrect info from some of the people who responded to your post. It is your responsibility to make your racecar legal. My suggestion would be for you to read the rulebook completely starting at page 1 to help you better understand the process.
#17 | |
And IMHO, the rulebook is intentionally vague and confusing...
#18 |
I get it Billy and I don't disagree ...…
I think that between the 2 of us we have been doing this for over a hundred years.... You have to learn for to walk before you learn how to run.... Starting out getting tossed is not a good thing... My big problem is people advising him that don't have the background.. Taking a conservative approach to the rulebook might not be a bad thing until you find out what's going on... It's better to know what is legal and what's not.. Take care..
#19 |
Liked 44 Times in 10 Posts
I think we spoke before about your combo. A while back. There are plenty of guys that build legal carbs that would make it a bit easier. Pm me & maybe I can point you in the right direction.
Tommy Baker SS/GA # 172 E/SA # 1272 |
#20 |
As a builder of Drag Race Thermoquads for over 40 years I can tell you the rule that you must have a choke plate in Stock and Super Stock has never changed! I wish it had! Would make my job a bit easier and the carbs a little faster. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
