#21 |
Liked 184 Times in 113 Posts
The impact is a bit more compression from the added stroke.
Draws .013 more air and then compresses .013 a differential of .026 Plus slightly smaller diameter crank diameter, less parasitic drag. Most engines it is about 1.5 cuin increase. Last edited by Dan Fahey; 07-08-2019 at 12:45 AM. |
#22 |
Liked 10,964 Times in 2,260 Posts
#23 |
Liked 783 Times in 195 Posts
Excuse me!?! Stroke is measured from BDC to TDC so the "differential" is .013", not .026".
#24 |
Liked 805 Times in 341 Posts
#25 |
Liked 397 Times in 153 Posts
No, no more than spec. You just don't have to deck the block as much.
Phil Molski PMR Performance S/C 1623 |
#26 |
Yes. And max compression is dictated by spec limits. Adding stroke does not increase compression except for the additional displacement added to the mix.
#27 | |
To me, the indexing and smaller pin size are at least equal in value. BTW, thank you to to Dwight for what you do for racers....Appreciated by 98% of them ,and called names by those who are Left.
#28 |
Gasket thickness (A) and deck (B) can vary, but total of A+B has to same as or greater than NHRA spec. .000 deck and .040 gasket = -005 deck and .035 gasket or +005 deck and.045 gasket. Give yourself a few extra thousandth to the good side so you can be fearless in tear down.
