Old 07-12-2019, 10:29 PM   #11
Eman
Liked 133 Times in 76 Posts
Default Re: MSD 8732 2 step sporadic fail
Power to what switch?
Old 07-12-2019, 11:25 PM   #12
cad
cad's Avatar
Liked 93 Times in 52 Posts
From the trans brake switch
Old 07-13-2019, 12:58 AM   #13
Mike Graham
Liked 341 Times in 67 Posts
That is not legal in super stock. The rule says that there can't be a splice in the transbrake wiring. The wire must go directly from the switch to the 2 step and the transbrake.
Mike Graham is offline   Reply With Quote
Old 07-13-2019, 02:24 PM   #14
Eman
As stated above it's not legal if that is an issue. Then I wonder what the theory is of using a relay. The 2 step obviously doesn't use much power. Generally controlling the transbrake solenoid with a relay isn't done or needed. Don't see what good a relay is going to do. Still think you have a bad connection somewhere.
Old 07-14-2019, 11:10 AM   #15
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Are we talking about a stocker with a brake pressure switch????
or
A super stocker with a transbrake button????
I'm confused?????
Bob Mulry 7516 STK
A & M Motorsports
Old 07-14-2019, 05:23 PM   #16
Biscayne
Biscayne's Avatar
Liked 2 Times in 2 Posts
Friend of mine had the same problem on a stick car with a 7AL 2. We would only only change the 2 step launch like 200 rpms and it changed like 800-1000 rpms when he actually put it on the two step. Its the diff switches that are the problem. A lot of guys have the same problem. He switched to The Grid. Problem solved.
Scott Chalk 1226 I/SA
Biscayne is offline   Reply With Quote
