Old 07-20-2019, 09:25 PM   #1
t-up
Default Lifter bore scratches
Do these scratches look like something I should be concerned with? Discovered them after getting block home from machine shop. I brought it back to the shop they acted like it was not big deal, honed the bores, said it was fine. Solid Roller Lifters
t-up is offline   Reply With Quote
Old 07-20-2019, 10:24 PM   #2
SSDiv6
Default Re: Lifter bore scratches
Not only scratches, but also appears to be a lot of pitting too.
They may create excessive leakage around the lifter.
What type of lifter will you be running?
Old 07-20-2019, 10:25 PM   #3
t-up
New have not been installed. Crower Cutaway Severe-Duty Roller Lifters 66291H-16
Old 07-21-2019, 09:23 AM   #4
Liked 11,000 Times in 2,263 Posts
For no surprises check lifter size with mike and bore size with bore gauge or telescoping gauge. If they used a ball brush hone, all that happened was the surface got scratch and bores got bigger.
Old 07-23-2019, 06:03 PM   #5
Frank Castros
We know the condition and the correction, but what is the cause?
Old 07-28-2019, 01:49 PM   #6
Vertical lines = trash
Old 07-28-2019, 02:17 PM   #7
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
www.lifterboretools.com has a kit for most popular V8 engines to sleeve lifer bores with bronze bushings. Not only restores your lifter bore to correct tolerance, but can restrict excessive oil flow. Kits have a reamer, install tool and bronze lifter bore bushings.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
