Old 07-30-2019, 04:50 PM   #1391
Dissident
Liked 73 Times in 36 Posts
Default Re: H-I-J '76 Nova re-fit.
Todd and Autumn,
Clip / Retainer come out and the pin slid out? What type of circlips were used? At what RPM did the thing come unwound? Bummer for sure.
You guys be tough and hang in there. Adversities makes one tougher, but it surely gets tedious at times.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 07-30-2019, 06:08 PM   #1392
Nmbr1GMfan
Originally Posted by nickh View Post
Todd pm sent.
Thanks, responded.
Todd Greene
Old 07-30-2019, 06:14 PM   #1393
Nmbr1GMfan
Todd, Do you have a pic of the other five pistons?
Mark, what would you like to see?
Todd Greene
Old 07-30-2019, 06:22 PM   #1394
Nmbr1GMfan
Originally Posted by Dissident View Post
Todd and Autumn,
Regards,
HB2
Dissident
Yes, Kramm-Lox, 5500 rpm.
Todd Greene
Old 07-30-2019, 06:24 PM   #1395
Nmbr1GMfan
Camshaft is on a 2 day trip to California.
Todd Greene
Old 07-30-2019, 07:31 PM   #1396
Dissident
Todd,
Did the clip break the end off of one end? What did the end of the pin look like? Such as did it ride on the cylinder wall a bit before it cocked in the piston and jerked in out of shape?
An old guy's inquiring mind would like to know. Thanks in advance.
Regards,
HB2
Dissident
Old 07-30-2019, 07:54 PM   #1397
Nmbr1GMfan
Todd,
Regards,
HB2
Dissident
Lock never broke, it was pushed out, pin was on the cyl wall and pulling on one side of the piston so it was jammed up in there. And yes, all of the locks were measured to make sure they had the correct groove size. before install.
Todd Greene
Old 07-30-2019, 08:39 PM   #1398
Liked 5,138 Times in 1,961 Posts
....Why I asked about the pistons..Should have mentioned the bottoms..not the tops ;-)
Old 07-30-2019, 09:26 PM   #1399
Nmbr1GMfan
Obviously the one that broke had no lock but another had no lock and the pin was out and about to break that piston too, both locks in the oil pan. Also should mention that the correct pins with the chamfer for this type of lock were also in use here.
Todd Greene
Old 07-30-2019, 09:53 PM   #1400
Rich Biebel
Rich Biebel's Avatar
Liked 549 Times in 215 Posts
I’ve never seen or used those pin locks.
My own engine in my dragster has Diamond pistons and spiral locks the std. used for many years. Single or double and I’ve never had one break or come out.
It was s.o.p. to verify the pins had some clearance or movement between the locks. Every piston I assemble, I check to be sure the pin can rotate freely in the piston without binding on the locks.
Obviously something way wrong with the lock, piston, pin arrangement.
That was a real bad mess and should not have happened given they were all good name brand parts.
Years ago we used a snap ring type pin lock. Spiral locks became the normal lock usually used. The locks tend to dig into the groove and raise up a burr but unless they were not installed right, rarely failed.
Very ugly mess. I’ve seen plenty of blown up engines. It’s never pretty and always expensive.
Sorry to see it ....
Rich Biebel
S/C 1479
Stock 147R
