#1581 |
Liked 10,969 Times in 2,261 Posts
Clutch!
#1582 |
As you will see in the videos, the clutch is too loose so we may be giving up a little bit there.
Todd Greene |
#1583 |
We had a few issues last night, one was with the water pump, I think it was just a funky connection so it was an easy fix. I'm a total Racepak newb so that was a struggle, biggest issue was not being able to get it to record, I ended up laying a laptop in the car and clicking a manual record button in the program every pass. Clutch needs a tightening up for sure. Autumn said the car had no power in Indy, although it was better here (far left timeslip is Indy the rest were last night, we only ran 1/8) you can clearly hear in the video it barely pulls rpm up in high gear at all. More work to do!
Todd Greene |
#1584 |
Liked 327 Times in 87 Posts
if Your checking 02’s here’s a small tip.
Place the curser over the o2 graph then left click the mouse. There will be a slide to adjust the sensitivity. I usually set mine 25 to 30. Cleans up the graph and makes it easier to read. |
#1585 |
Liked 57 Times in 24 Posts
Hi,Todd
I am a racepak newb also. Have only about 12 recordings Are you trying to starting recording automatically or do You have a manual start button.I have ours set up on a manual Button.I Just press it after I get the top bulb light. I have a configure File to auto start but I have not downloaded and try. If manual Starting you can test without running the car. We have a sportmans With 1 O2 sensor and oil pressure sensor added I can email you A screen shot of where the record start selection is. Hope this helps some David |
#1586 |
Thanks.
Todd Greene |
#1587 | |
Todd Greene |
#1588 |
I tried to attach a screen shot of setup location of record
Selection Don't know if it sent. If not PM your email and I Can try to send it that way. |
#1589 |
Liked 6 Times in 6 Posts
Is it normal to lose 8 mph between 1/8 and 1/4 ?That just looks wonky.
#1590 |
Liked 8,218 Times in 1,537 Posts
