#1661 |
Liked 280 Times in 139 Posts
What's up in the 1st rd,on live timing it shows the car dialed at 11.30 and no other incrementals.Shows Cagnazzi the winner...gsa612 *edit* we both posted at the same time.I had the rotor loosen off tore the s*** out of the cap.
#1662 |
We had a great matchup with Victor Cagnazzi today for first round which was kind of cool since Autumn first met Victor about 2005 and he has always been super cool. Unfortunately, in the burnout the car just abruptly shut off, got it back and started checking everything (we were expecting the worst) and turn out the little screw on the rotor came off and poof... the two piece rotor is in fact... a two piece rotor (maybe we need a Loctite sponsor
Todd Greene |
#1663 |
Liked 335 Times in 182 Posts
Todd and Autumn---that might partially explain why the engine did not want to rev under a load as it was "partially retarding the timing" --- might want to replace the cap along with the rotor and in the future put a drop of loctite or silicone on those threads to keep them snug---its possible in all your thrashing and assembly that the "screw" really never was tightened merely snugged from the get go---I'm impressed its all coming together very nicely --- Optimistic for your future results--- might want to RE-DYNO the engine in an as is configuration and then try "some things" on the dyno to see what it likes--- looking for that sweet spot so to speak---Regards FED 387
#1664 | |
Todd Greene |
#1665 |
Liked 719 Times in 220 Posts
I just went out and pulled the distributor caps on both my Monte Carlo and my wagon and put a drop of blue Loctite on the rotor screw threads. A thing like this is worth checking. One thing about race cars, you never seem to run out of things to do where they are concerned.
#1666 | |
Todd Greene |
#1667 |
Liked 320 Times in 102 Posts
Just a heads up....
The screw coming loose on the 2 piece rotor will only change the rotor phasing and not the timing.. Just sayin'
#1668 |
Then the timing was ok, rotor phasing, not so much.
Todd Greene |
#1669 |
After some maths and assumptions, if we move to our natural class (I) our -.639 could be a -.689 and with a couple issues we have sorted out I honestly think we could go .80 under in great weather. Probably not with the old headers we're going to try, but if I can get some torque back with a collector swap or extensions on the new headers or maybe a gear swap (have to check the tach first) we might get close.
Todd Greene |
#1670 |
Liked 10,926 Times in 2,257 Posts
Back to back at the track. It's work but it beats wondering.
