Old 11-16-2018, 01:25 PM   #51
Default Re: 302 Chevrolet Engine Build
Larry, Do you have this type of equipment at your place? I know you do a lot of your own work.
Old 11-17-2018, 02:42 PM   #52
Liked 10,960 Times in 2,260 Posts
Yes I have owned a Diesel machine shop. Built toy airplane engines with Harry Paul Tune and burnt Drums of nitro every toy airplane season. If we wanted to go fast with the toy airplanes, we would use laboratory grade nitro, its clear without yellow die.
Old 11-17-2018, 08:42 PM   #53
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by MIKE JONES 302 View Post
I turn the block 180 degrees to keep the mandrel tru. I adjust oil flow to slow down the honing rate. The 3 center mains can not be over stroked, they hone faster than 1 and 2 mains. I do use a truing sleeve on the rod hone mandrels, but I've never seen a truing sleeve for a line hone mandrel, but I just started machining. Could you post up an image of a "Line hone mandrel truing sleeve" Thanks
Here you go Mike LOL
Name:	Truing sleaves.jpg
Old 09-07-2019, 10:03 PM   #54
MIKE JONES 302
Liked 85 Times in 15 Posts
I got the pistons last week, Icon .040 -12.7 CC dome, they came in at 712 grams with pin after some work.
MIKE JONES 302 is offline   Reply With Quote
Old 09-07-2019, 10:33 PM   #55
monte385
Liked 27 Times in 19 Posts
I have a feeling you've had a pretty good teacher during your life.
monte385 is offline   Reply With Quote
Old 09-07-2019, 11:26 PM   #56
dc1320Fan
Liked 17 Times in 11 Posts
It is very encouraging to see a person of Mike's age using his head and hands to do something that he is interested in. He not only has had good instruction but is obviously receptive to learning all he can. Not easily found in young workers today. I see a bright future ahead for you Mike.
dc1320Fan is offline   Reply With Quote
Old 09-08-2019, 09:47 AM   #57
MIKE JONES 302
The finished piston. Some more pictures of sizing the wrist pins, size was set at .0008. I have to drill and tap the crank snout next and have the crank flange cut, then I can balance the assembly. My dad will hone the block then I can assemble the short block.
ID:	51769   Click image for larger version
ID:	51770   Click image for larger version
ID:	51772   Click image for larger version
ID:	51773   Click image for larger version
Old 10-26-2019, 10:06 PM   #58
MIKE JONES 302
I got this for my Birthday, the 302 will go in this until I build a 427 for F/SA.
Old 10-27-2019, 07:19 AM   #59
You'r going to need a bigger trailer!
Old 10-28-2019, 03:26 PM   #60
Makinchips
Safety glasses on??
Makinchips is offline   Reply With Quote
