Old 11-19-2019, 11:43 AM   #171
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Default Re: Nova stocker project.
Very well done and fast !
Let us know how your freshened engine works out.
Old 11-19-2019, 12:20 PM   #172
Liked 5,146 Times in 1,964 Posts
Good that you found those problems early.
Looking forward to those dyno sheets.
Old 11-19-2019, 07:45 PM   #173
Alan Nyhus
Liked 799 Times in 236 Posts
Yes...the lobes had begun to look herky earlier in the season but the leading/trailing edges of the nose were still okay. The lash wasn't changing but toward the end of the season it got 'flat' and unresponsive to changes so I wasn't surprised to see half a dozen like this when I took it apart.
The last pass on it was at the Div 5 Nat. Open at Kearney, Ne and it went -.88 and change under.
Stocker Life.....
"That'll never work....."
Old 11-19-2019, 08:10 PM   #174
Markeracer
Liked 67 Times in 28 Posts
What lifter are you using and how crazy is the spring pressure?
Markeracer is offline   Reply With Quote
Old 11-19-2019, 08:16 PM   #175
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Nova stocker project.
tell us what you found out about the spots on the cam lobes. I had the same thing happen on two different engines and got all kinds of reason's for it happening but nothing definite. Oil, spring pressure,lifters etc... etc. Sure would be nice to know for sure what caused it.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 11-19-2019, 09:05 PM   #176
HP HUNTER
Liked 373 Times in 129 Posts
Alan
You should think about running the Stock Super Stock combo races @ Bandimere. There will be several G/SA cars there, so your Chevy will feel right at home. Denver's cars are usually fast so you'll have good cars to compare to.
Old 11-19-2019, 09:50 PM   #177
Alan Nyhus
Originally Posted by HP HUNTER View Post
Alan, You should think about running the Stock Super Stock combo races @ Bandimere. There will be several G/SA cars there, so your Chevy will feel right at home. Denver's cars are usually fast so you'll have good cars to compare to.
Making plans to head that way next season. -Al
Old 11-19-2019, 10:09 PM   #178
HP HUNTER
Thats great! Let me know when your coming. I think in this area of the country the Denver weather is better, the track is better, less wind, of course the baro is horrible but its all relative. Kearney is always a train wreck for me, I like the town but never seen to be able to get it done there, the weather always gets me.
Old 11-20-2019, 09:20 AM   #179
Alan Nyhus
Trend lifters and PAC 1409X springs.
https://www.racingsprings.com/index....ring-8086.html
Bill, I think there's just a certain life expectancy of this style of lobe. There's a tremendous amount of pressure concentrated on a very narrow 'peak' on both the opening and closing sides of the lobe.
This would be a good topic for the Tech section, for sure. -Al
Old 11-20-2019, 08:29 PM   #180
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Alan,
Good luck during the off-season! No rest for those in a performance based category, as there is always something to improve on or look at.
Sean
Sean Marconette
84 Mustang
5060 SS/N
