Old 11-27-2019, 08:59 AM   #251
Liked 10,927 Times in 2,258 Posts
Default Re: Dumbo The Flying Elephant
TCI
Working on heavy equipment I know about the ax, it has been my friend for years.
Old 11-28-2019, 08:50 AM   #252
Engine is out, now off with its heads and other parts.
Old 11-29-2019, 08:36 AM   #253
Got to go to the steel store today. I have to make fixtures for block strong enough to keep it level while I install torque plates.
Old 12-02-2019, 09:20 AM   #254
Got it built. My 5.7 holds 43 oz. of water per side any more than that it runs out of the water pump passage. Still a lot to do before race day.
Old 12-02-2019, 12:05 PM   #255
Alan Nyhus
Liked 800 Times in 237 Posts
Larry, did you find the leak?
"That'll never work....."
Old 12-02-2019, 01:04 PM   #256
Not yet
Old 12-03-2019, 08:40 AM   #257
A word of thanks to everyone that has helped, advised, did my thinking for me, text, called, posted, and joked. You know "How many Hillbilly's does it take to ..............". Thanks for helping me along and being a part of the team.
I really enjoy the tear down part of the engine it give me a new list of how and why this or that happened. Got to go Dumbo is calling
Old 12-06-2019, 08:37 AM   #258
Since I'm the engine builder I will have to take the blame. A air leak, @ 45 psi, was found at block to front cover. Water flows both directions to and from water pump through front cover. Will check block and cover for flatness, O ring grove for depth and finish, and O ring type gasket for cuts. Reassemble and re check.
Checking tool was a blocked off water pump, 0-60 psi tire gauge, Schrader valve. Gauge was piped in.
Old 12-06-2019, 09:34 AM   #259
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Good job finding that leak! Better than a crack somewhere.
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 12-06-2019, 01:56 PM   #260
Leaking in chain area
