Old 12-27-2019, 09:46 PM   #61
MIKE JONES 302
Liked 85 Times in 15 Posts
Default Re: 302 Chevrolet Engine Build
I got some parts for Christmas, so I plan on getting the short block together next week. I mounted my pistons up, and drilled the crank snout for the balancer bolt, a friend of mine faced the crankshaft flange for me. I balanced the assembly today, it needed 4 grams on the front and 9 grams on the rear, both on the crank pin side. My Dad will hone the block for me and I can start assembly.
ID:	53065   Click image for larger version
ID:	53066   Click image for larger version
ID:	53068   Click image for larger version
ID:	53069   Click image for larger version
MIKE JONES 302 is offline   Reply With Quote
Old 12-28-2019, 09:23 PM   #62
MIKE JONES 302
Block is honed and final cleaned, should have a finished short block tomorrow.
ID:	53108   Click image for larger version
ID:	53109   Click image for larger version
Old 12-29-2019, 10:49 PM   #63
MIKE JONES 302
I got the short block assembled, took a while to get the bearing clearance set. I was looking for .0025 on the mains, and the number 2 main was coming in at .0023, I was able to sand the back of bearing, really just cleaned it up and got the .0025 I was looking for, the rest went together good with no problems, I had .0022 on the rods. The picture of the main bearings # 2 sanded, the number 1 as produced. Now the work will start, the heads are next, thats going to take some time.
ID:	53166   Click image for larger version
ID:	53167   Click image for larger version
Old 12-30-2019, 11:46 AM   #64
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: 302 Chevrolet Engine Build
What a nice immaculate clean place to work! I'm impressed with the quality of detail put into this project! Keep doing things right as you go along.
Old 12-30-2019, 09:05 PM   #65
MIKE JONES 302
Thank you, I will do my best.
Old 12-30-2019, 09:15 PM   #66
I have a feeling these Jones Boys won't be a secret too much longer ;-)..
Old 01-04-2020, 09:15 AM   #67
Frank Castros
Liked 2,795 Times in 983 Posts
Very impressive young man!
Old 01-04-2020, 02:16 PM   #68
Liked 11,032 Times in 2,267 Posts
Things look great, keep it up!
When I looked that young, it was a few years before G I Joe was invented.
Old 01-04-2020, 07:58 PM   #69
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
G I joe with the kung foo grip !
Old 01-05-2020, 05:29 PM   #70
MIKE JONES 302
Got started on the heads a while back, machined for screw in studs and guide plates. Installed the guides and honed them to size, and cut for seals. I then started on the intakes by unshrouding the chambers and hogging the bowls for the 2.020 seat. I then cut the intake seat and set height. The exhaust seats were next with the height set.
ID:	53289   Click image for larger version
ID:	53290   Click image for larger version
ID:	53292   Click image for larger version
ID:	53293   Click image for larger version
