Old 04-06-2020, 08:35 AM   #1
SST159
Liked 20 Times in 16 Posts
Default Onan Generator part needed
Need to replace the access door to the oil/fuel filter.
Onan Quiet Diesel 7500, Model 7.5HDKAJ1145J, spec J.
Anyone know where I can locate this part.
I have searched the manuals online but no success on this part number.
Thanks in advance.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 04-06-2020, 09:35 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 549 Times in 215 Posts
Default Re: Onan Generator part needed
The trap door that swings down ?
I can look it up for you...
Complete door part number is 405-5818-S Zero
$75 list price....from Cummins.....
Rich Biebel
S/C 1479
Stock 147R
Old 04-06-2020, 09:46 AM   #3
SST159
Yes.
the plastic slide latch broke which holds it in the closed position.
I don't need the hinges just the door if available that way.
thanks.
Drew Wonderly
SST 159
Old 04-06-2020, 10:06 AM   #4
Rich Biebel
Plastic slide latch.... Part #406-0612 2 per door...
If you have a Cummins-Onan dealer in your area they should be able to get them for you....
Or maybe you can find them for sale somewhere on the internet....
Rich Biebel
S/C 1479
Stock 147R
Old 04-06-2020, 01:25 PM   #5
SST159
Thanks Rich.
Really appreciate it!
Drew Wonderly
SST 159
Old 04-19-2020, 11:39 AM   #6
Dewdlebug
Liked 23 Times in 15 Posts
The plastic latches are available separately. Rich did the hard part and provided the part #. Installation is simple.
Dewdlebug is offline   Reply With Quote
Old 04-20-2020, 12:23 PM   #7
Rich Biebel
I can look up any ONAN generator part and only need the machines Model info found on it's label...
I can tell you the part numbers and the cost. All Onan parts direct from them.
I can also drop ship parts directly to you and we accept CC's over the phone...
This is not a primary service here where I work but we are an Onan dealer and I have done it for many racers in my area as well as other parts of the country.
Primarily I repair and service them and in normal times I'd be very busy this time of year. RV and commercial users of Onan generators would be making appointments for service and repairs...
The Virus Pandemic has certainly changed that !!
Rich Biebel
S/C 1479
Stock 147R
Old 04-20-2020, 01:02 PM   #8
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Hey Rich, I have a QuietDiesel 7500 in my toterhome that could use a new exhaust. What could I generally expect to pay a shop to do that?
S/ST 51
S/C 53
Old 04-21-2020, 01:56 PM   #9
Rich Biebel
I could not really estimate what that would cost without taking a look but it has to be removed and covers removed to do any kind of work....
The removal and replacement of one in a diesel pusher is a difficult process....I've done many over the years. On a Toter it's usually not so bad.....compartment mounted somewhere on the side...usually
It would not be hard to get to $2 grand or more...I generally do a complete service and change some parts known to fail while I'm in there.
The flex pipe coming off the engine breaks on those.
The flex pipe alone is well over $200...
External pipes are usually custom made or made from Onan pipes readily available.....
Rich Biebel
S/C 1479
Stock 147R
Old 04-22-2020, 11:41 AM   #10
SST159
Thanks Rich,
This is good to know for future. Had I known I would have ordered it through you.
Thanks again for your help.
Drew Wonderly
SST 159
