Old 04-08-2020, 05:08 PM   #71
Frank Castros
Liked 2,768 Times in 980 Posts
Default Re: 302 Chevrolet Engine Build
Mike,
What's new with your project?
Old 04-09-2020, 10:29 AM   #72
MIKE JONES 302
Liked 85 Times in 15 Posts
I have been working on the head porting, a lot of time spent on this.
ID:	54386   Click image for larger version
MIKE JONES 302 is offline   Reply With Quote
Old 04-09-2020, 11:50 AM   #73
Jim Hanig
Liked 99 Times in 49 Posts
On a stocker?
Old 04-09-2020, 12:34 PM   #74
Originally Posted by Jim Hanig View Post
On a stocker?
No.
Looking forward to the dyno tests..
Old 04-09-2020, 01:30 PM   #75
Liked 11,012 Times in 2,263 Posts
Those B'ski fixtures are very time saving. You may want to try modeling clay to help raidus the inlet adapter, it will help reduce noise.
Old 04-10-2020, 12:21 PM   #76
Glenn Briglio
Glenn Briglio's Avatar
Liked 977 Times in 312 Posts
And smooth out the manometer!
Glenn Briglio is online now   Reply With Quote
Old 04-11-2020, 02:22 PM   #77
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Looking good... Mike...
I grew up in service station/garage.. which transititioned to machine shop...
When I was 12-13 years old people were a little freaked out, when I had their heads off or swapping cams or working on their brakes...…learned a lot, especially about people
Doing what you are.... you have evidently spent a lot of time watching and learning..
Is that what your Dad does for a living?
Old 04-12-2020, 10:39 AM   #78
MIKE JONES 302
I thank everyone for their support and help. My inlet radius was given to me be the Disident and it fits the port perfect, it is joined to the port by green modeling clay, nasty stuff thats hard to get off. anything it touches. I have 254 CFM @ .650 lift with a 4.030 bore @ 28 inches, I want a solid 260. I do work in the shop with my Dad.
Old 04-13-2020, 03:04 PM   #79
Dissident
Liked 73 Times in 36 Posts
For those who have made comments about the radius entry piece that Mike is using while flow testing his project 302 heads....It is NOT a Brezyinsky piece. It is home grown and cast right here in Colorado. It employs a very liberal radius and is adequately thick to encourage no "edge effects" from lesser radii designs.
Mikey, keep doing what you are doing and enjoying it too!
BTW - If one sees the manometers bouncing around, it is typically a sign of bi-stable airflow that needs to be addressed in the port, not from just changing the radius inlet guide.
Regards to All that like this kind of stuff,
HB2
Dissident
Last edited by Dissident; 04-13-2020 at 03:06 PM. Reason: correct spelling error and spacing
Dissident is offline   Reply With Quote
Old 04-13-2020, 03:57 PM   #80
Jeff Stout
Liked 708 Times in 285 Posts
I hope I can explain myself correctly. I believe you use a wand to go into a port and measure air speed or flow I guess. If the air speed drops alot on a inside radius of port, would you want to fill the radius to get speed up or get a larger radius to help speed up air? If it sounds like I don't know what Im talking about just say so as I have not been around flow benches all but a couple times
