#351 |
Liked 242 Times in 81 Posts
pics or it didn't happen.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#352 |
Liked 11,006 Times in 2,263 Posts
I thought the video would have been up by now. As Jeff would say that is way above my pay grade.
Patsy tried to upload to photobucket but it would not load. I think its on facebook. Last edited by Larry Hill; 04-12-2020 at 09:11 AM. |
#353 |
Update, yesterday was test drive day or so I thought. Add water, fuel, recheck trans fluid , pull car up to house shut it off and check for leaks. No hits ,no runs and no errors, I strap myself in hit the starter and nothing. Just another day at the office.
#354 |
Broken solenoid
#355 |
Great video on face book. Looks like it scared Chris
#356 |
Liked 3,244 Times in 986 Posts
Can someone share the video? I can't find it on FB
#357 |
When I shift the car to high gear it seems to want to move right along. Those M W brakes work real well.
I drove 330 plus miles to have a set of shocks dynoed. Man are those things sensitive on adjustment. I think we now have a place to start from to sort the car out, I hope. After we get the car back together, the real test will be figuring out what boards to make to load the car without damaging the plastic splitter. Last edited by Larry Hill; 04-18-2020 at 12:22 PM. |
#358 |
Liked 67 Times in 27 Posts
I have two race ramps to go under the trailer door then I put a 1" X 6" board halfway down the ramp to clear mine.
Dennis Breeden |
#359 |
Put the car on the lift after a little test drive just to check everything. Reinstall the shocks and changed the direction of the attachment bolts to make it easier to service. Had to shorten one 1/2'' x 20 NF bolt two threads or .100'' to get the type clearance I want. Rechecked differential gear oil it was low as expected, it was full. The missing oil went in the tubes to oil the wheel bearings.
Cut my hand on a long screw sticking out passed a RivNut, now they don't stick out anymore. I had one screw rubbing on a borrowed collector, it's fixed now. I'm working on installing an air filter on the car. It always happens on the way to staging, I'm behind some one raising a cloud of dust, not their fault. So to make my engine last longer its going to have a filter for the air. |
#360 |
Liked 373 Times in 129 Posts
Larry
Yac was telling me about your truck today, I had no idea. What front brake setup did run on it? |
