Old 04-16-2020, 07:43 AM   #1731
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: H-I-J '76 Nova re-fit.
I would say they ought to reverse the 1-2 rpm with the 3-4.
This wouldn't be from a dyno sheet..Just experience.
It will go faster if you get it out of first gear sooner.
Old 04-16-2020, 10:02 PM   #1732
Nmbr1GMfan
Originally Posted by Glenn Briglio View Post
Have you tried shifting lower......those engines don't make power up that high.
It goes slower shifting lower.
Todd Greene
Old 04-16-2020, 10:08 PM   #1733
Nmbr1GMfan
This thing is such a dog in high gear you almost have to hold every gear as long as you can, if you shift 3-4 200rpm lower it will barely climb any rpm at all, just sits at 6800 and lumbers to the stripe. I don't know if it's the 1 goofy head thats on it or the cam. Hopefully we get some real dyno time at the end of the year to swap some parts and figure it out.
Todd Greene
Old 04-16-2020, 10:13 PM   #1734
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Something sounds off.........it should be making maximum power right around 6800 rpm.What rpm does it drop to on shifts.
Old 04-16-2020, 11:04 PM   #1735
Nmbr1GMfan
Originally Posted by glenn briglio View Post
something sounds off.........it should be making maximum power right around 6800 rpm.what rpm does it drop to on shifts.
5800-6000 Also Glenn in my previous post I meant to say drops to 5800 and won't move.
Todd Greene
Old 04-17-2020, 06:25 AM   #1736
Glenn Briglio
Clutch slipping?
Old 04-17-2020, 10:34 AM   #1737
Nmbr1GMfan
Clutch slipping?
Absolutely not. Just dead, no power.
Todd Greene
Old 04-17-2020, 12:14 PM   #1738
Hacksaw
Liked 312 Times in 175 Posts
Camshaft ?
Old 04-17-2020, 01:15 PM   #1739
Jim Hanig
Liked 99 Times in 49 Posts
where is the cam center line 105? how much flywheel 35 lbs 3.29 low? 5.38 gear.
Old 04-17-2020, 02:24 PM   #1740
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Running out of fuel?
