Liked 419 Times in 96 Posts
What are the "Best Battery Chargers" to use for between round charging?
We've used Schumacher, Sears/Craftsman, and Optima Digital Battery Chargers. Curious to see what others are using and reasons/benifits/opinions why? Thanks |
Liked 900 Times in 191 Posts
Greg - I used harbor freight - it's cheap and does the job! (I turned Greg Gay on to one of these and he bought one too).
Bob Don 128 SS |
Liked 100 Times in 51 Posts
This question is so vague. It depends on what type of battery you’re trying to charge. Also, are just trying to make the next round or trying to get the most life from the battery? Charging a battery incorrectly will cause premature failure.
Dan
Dan Foley SC 4698 |
Liked 310 Times in 174 Posts
Can't say it's the best but I've had a Morosso 12v/16v charger for almost 20 years. Use it on everything. Still love it, won't jump start but has sleep mode.
Liked 2,484 Times in 697 Posts
We use the same Harbor Freight chargers on our conventional batteries. Optima charger on the Optima batteries at Track.
Back at the shop with more time = Optima's on all of them. BUT the Optimas are expensive/Hard to Find anymore AND rather Fragile!
Liked 129 Times in 59 Posts
I've been using a Schumacher Ship-N-Shore Model XCS-15 I bought at Bass Pro-Shops. It charges Standard, AGM and Gel batteries at 3 or 15 amps, and gives you a "% of charge" as well as voltage.
The only downside is that if your Optima is heavily discharged, the Auto-Voltage feature doesn't know it's a 12-volt battery, and will only charge SIX VOLTS. You need to hook up another good 12 volt battery to get the charger to work properly. That shouldn't be an issue with between rounds top-offs. Good Luck!
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 91 Times in 51 Posts
I forgot about this one. Luke Siebert uses one on his camaro and nova.
https://cloreautomotive.com/product/pl2320/ It has a 20a charge, which is higher than most, and the company is out of Lenexa, KS. It is $79 on amazon prime right now. -- https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I just ordered one as we have been using my dad's stand-up NAPA charger, but it is a big machine, and Im getting tired of moving it around/loading/unloading. Clark |
