#381 |
Liked 11,032 Times in 2,267 Posts
On a Mopar it will only bolt up one way without a lot of clearance
#382 |
Liked 165 Times in 59 Posts
what transmission are you using?on my 904 the converter has to be clocked to match the flex plate,, gmonde
#383 |
SB 727, all converters I have seen are the same for the B, RB, and SB 727
#384 |
Liked 315 Times in 178 Posts
Sounds like the holes in the flexplate are off, check that?
#385 |
Liked 695 Times in 206 Posts
I had the same issue. Before installing the 904 in my Challenger, I bench checked and marked the flexplate and converter to make sure the bolts would line up. Everything lined up perfect and bolted together. Once I bolted the flexplate to the crank and installed the transmission, the one odd bolt was extremely hard to get started. I think the process of torqueing the flexplate distorts it enough that the bolts are all hard to install.
#386 |
Hacksaw
I would normally agree but Brand "X" converter came out and Brand "Y" will not bolt up. Just a guess Brand "Y" might be the problem. But it will be installed. |
#387 |
Liked 7,925 Times in 1,760 Posts
I don't know squat about Mopars but I ran into a FFFord once where the snout on the converter was just a tad too long for the back of the crank. It was just enough that you could bolt up the converter with no (noticeable) problem but it wasn't happy.
#388 |
A little toy airplane technology and all is good. Thanks everyone for the comebacks and text. Toy Airplane Technology is a Dremel Tool or 5 Minute Epoxy.
#389 |
Still to do: change oil and filter, install drive shaft, install passenger's seat, check logging graph, top off trans fluid, hook up auto shift, and test drive.
I did get to see all of the NASCAR race |
#390 |
Spoke with Brand "Y" converter maker and said they would gladly check it over and report. I expected nothing less from a quality company.
