Old 05-17-2020, 09:54 AM   #381
Liked 10,926 Times in 2,257 Posts
Default Re: Dumbo The Flying Elephant
On a Mopar it will only bolt up one way without a lot of clearance
Old 05-17-2020, 10:06 AM   #382
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
what transmission are you using?on my 904 the converter has to be clocked to match the flex plate,, gmonde
Old 05-17-2020, 10:36 AM   #383
SB 727, all converters I have seen are the same for the B, RB, and SB 727
Old 05-17-2020, 10:46 AM   #384
Hacksaw
Liked 314 Times in 177 Posts
Sounds like the holes in the flexplate are off, check that?
Old 05-17-2020, 11:56 AM   #385
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I had the same issue. Before installing the 904 in my Challenger, I bench checked and marked the flexplate and converter to make sure the bolts would line up. Everything lined up perfect and bolted together. Once I bolted the flexplate to the crank and installed the transmission, the one odd bolt was extremely hard to get started. I think the process of torqueing the flexplate distorts it enough that the bolts are all hard to install.
Old 05-17-2020, 12:08 PM   #386
Hacksaw
I would normally agree but Brand "X" converter came out and Brand "Y" will not bolt up. Just a guess Brand "Y" might be the problem. But it will be installed.
Old 05-17-2020, 12:16 PM   #387
Billy Nees
I don't know squat about Mopars but I ran into a FFFord once where the snout on the converter was just a tad too long for the back of the crank. It was just enough that you could bolt up the converter with no (noticeable) problem but it wasn't happy.
Billy Nees 1188 STK, SS
Old 05-17-2020, 01:24 PM   #388
A little toy airplane technology and all is good. Thanks everyone for the comebacks and text. Toy Airplane Technology is a Dremel Tool or 5 Minute Epoxy.
Old 05-17-2020, 08:04 PM   #389
Still to do: change oil and filter, install drive shaft, install passenger's seat, check logging graph, top off trans fluid, hook up auto shift, and test drive.
I did get to see all of the NASCAR race
Old 05-18-2020, 01:02 PM   #390
Spoke with Brand "Y" converter maker and said they would gladly check it over and report. I expected nothing less from a quality company.
