#11 |
Just curious with the new online tech cards, since this will be my first time filling one out for S/G and S/ST. Do you have to check every single box on the tech card such as the ones that says, throttle, fire extinguisher, roll bars, roll cage, tires etc. ? These seem like obvious things a car would have but since im new to this I am confused. Dont wanna F it up.
#12 |
Just check the boxes you used to address when you filled out your card at the track. Then you will enter your serial numbers and expiration dates.
Ray Todd 4604 S/ST |
#13 |
I have never filled one out before. This will be my first time.
#14 |
Liked 1,887 Times in 579 Posts
If you have a throttle then check it (Doesn’t everyone)
Same with bar or cage. Check One or the other Check all that applies if there is a question it won’t be accepted then you can double check and Try to send Again
#16 |
Liked 134 Times in 70 Posts
When I filled out the one for Tulsa. I filled out what I normally would. I punched in the Flexplate, Flexplate Shield etc. It made me go back to Flywheel stuff. Anything that didn't apply I just put in N/A.
