Old 08-25-2020, 12:26 PM   #591
There was a '68 Bird, which ran back in the late '90's & early 2000's. Sometimes the driver is listed as Jack Treola, sometimes as James Treola. Both names are listed as being from WV. Sometimes the # was 9049. Sometimes it was 3049.
Jack and Bill were a couple of really nice fellows, who I believe, won the Div. 3 championship in the mid- 90's .I haven't heard anything lately about them or the car.
I don't recall if you covered Ron Prince's 68 Bird, which stays pretty close to the Brainerd area.It has a Line engine, I believe.
Old 08-26-2020, 02:50 AM   #592
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
"...I don't recall if you covered Ron Prince's 68 Bird, which stays pretty close to the Brainerd area.It has a Line engine..."
I probably mentioned it. But may have not posted many race results for the car. I suppose the reason for that may have been that it did not post any really big qualifying numbers, or show up in the finals of lots of races, like some of the other cars mentioned here.
For SOME driver names, the DRC search function works real good. For some, not very good. And for some, not good at all.
Ron Prince's '68 shows up on DRC in 1998. So, I don't know when he started racing it.
8/22/98 - BIR Northstar Nats - #32 - .856 under.
https://www.dragracecentral.com/DRCS...r1998#indextop
10/3/98 - Topeka - #26 - .760 under.
https://www.dragracecentral.com/DRCStory.asp?ID=43990
6/24/99 - Sears Nats - #29 - .831 under.
https://www.dragracecentral.com/DRCStory.asp?ID=51592
8/20/99 - BIR - #20 - .885 under.
https://www.dragracecentral.com/DRCS...r1999#indextop
8/17/01 - BIR - #44 - .685 under.
https://www.dragracecentral.com/DRCS...r2001#indextop
9/8/02 - div 5-6 - #68 - .697 under.
https://www.dragracecentral.com/DRCS...r2002#indextop
9/6/03 - div 5-6 - #85 - .585 under.
https://www.dragracecentral.com/DRCS...r2003#indextop
He's listed driving a '69, in '04. Maybe it was just a typo on DRC, & he was really driving the '68 Bird at these races. Obviously, I don't know.
6/5/04 - div 5-2 - #54 - .536 under.
https://www.dragracecentral.com/DRCS...r2004#indextop
8/13/04 - Lucas Oil Nats - #53 - .825 under.
9/11/04 - div 5-6 - #73 - .789 under.
He lived in MN, so he mostly raced the div 5 races & the national event at BIR.
https://www.brainerdraceway.com/facilities/drag-strip/
In '05 he was running real low 11's, in E/SA. Back then, the index was only 12.00. So, an 11.10 would give you a fairly good qualifying number, of .900 under the index. Here's a couple in the 11.10-11.12 range, in '05.
9/10/05 - Earlville - #36 .894 under.
https://www.dragracecentral.com/DRCS...r2005#indextop
8/12/05 - BIR - #27 - .877 under.
6/3/06 - div 5-2 - #28 - .815 under.
https://www.dragracecentral.com/DRCStory.asp?ID=115422
5/26/07 - div 5-2 - #30 - .847 under.
https://www.dragracecentral.com/DRCStory.asp?ID=136082
5/24/08 - div 5-2 - #30 - .796 under.
https://www.dragracecentral.com/DRCStory.asp?ID=158901
5/23/09 - div 5-2 - #41 - 11.85 index - .777 under.
https://www.dragracecentral.com/DRCStory.asp?ID=181830
8/14/09 - Lucas Oil Nats - #55 - .657 under.
https://www.dragracecentral.com/DRCStory.asp?ID=188968
8/13/10 - Lucas Oil Nats - #39 - .469 under.
https://www.dragracecentral.com/DRCStory.asp?ID=212066
The first 10 sec ET's I found for his '68 Bird were in 2011. They were 10.80's, in D/SA, which had an index of 11.55.
5/28/11 - BIR - #14 - .719 under.
https://www.dragracecentral.com/DRCS...r2011#indextop
8/19/11 - BIR Lucas Oil Nats - #22 - .679 under.
Don't know what the car's best ET is. This 10.807 is the best I've found.
6/4/16 - div 3-3 - #33 - 10.807 - .743 under.
https://www.dragracecentral.com/DRCStory.asp?ID=313092
8/13/16 - div 5-5 - #42 - 10.883 - .667 under
https://www.dragracecentral.com/DRCStory.asp?ID=316804
8/19/16 - Lucas Oil Nats - #32 - 10.831 - .719 under.
https://www.dragracecentral.com/DRCStory.asp?ID=317027
https://www.dragracecentral.com/DRCS...r2016#indextop
8/18/17 - Lucas Oil Nats - #44 - 10.914 - .636 under
https://www.dragracecentral.com/DRCStory.asp?ID=329696
In 2018, he qualified with a 10.90, survived 6 rounds of elims, at a div 5 race, but got treed in the final & had to settle for R/U.
8/12/18 - BIR - #38 - 10.906 - .644 under - R/U.
https://www.dragracecentral.com/DRCS...r2018#indextop
Ran a 10.98 at last year's BIR nat event.
8/15/19 - Lucas Oil Nats - #46 - .566 under.
https://www.dragracecentral.com/DRCS...r2019#indextop
He ran 4 div 5 Lucas Oil Series races last year, including the doubleheader at Topeka, & this one at Earlville.
9/7/19 - Earlville - #87 - 10.896 - .654 under.
https://www.dragracecentral.com/DRCStory.asp?ID=356180
So, he's been racing it a long time, & has made lots of 10 sec runs. By no means the quickest '68 Stock class Bird, ever, but probably in the top 10. I don't have an accurate count. But, I assume there have been less than 10 Stock class '68 Birds, which have been able to run in the 10 sec zone. I only have 7 listed in my Stocker pics files. Hey, if ya'll know of others, please post that info.
(1) Leo Glasbrenner
(2) Bob Aceves
(3) Adam Strang
(4) Chris Stephenson
(5) Tim Gillespie/Julie Biermann
(6) Todd/Duane Hoven
(7) Ron Prince
Name:	1 - R. Prince @ Lucas Oil Nats  .jpg
ID:	55390   Click image for larger version
Name:	2 - Ron Prince .jpg
ID:	55391   Click image for larger version
Name:	3  - Ron Prince .jpg
Name:	4 - Ronald Prince .jpg
ID:	55393   Click image for larger version
Name:	5 - Line Perf .jpg
Old 08-28-2020, 02:01 AM   #593
oldskool
oldskool's Avatar
Saw this today. Don't remember ever reading it before, tho I may have.
"...Sadly Chuck White passed away in 1976. Ken & Art both gave up racing at that time but Bill Kissinger continued racing this T-37 until 1979. Bill then raced a RA IV powered '70 Trans Am until the mid 80's..."
This was in an article about a Pontiac that the White bros raced.
http://www.tarheeltigers.org/1971-t-...%20Brothers%20
So, does anybody here know Bill Kissinger or anything about the the "...RA IV powered '70 Trans Am..." that he raced ?
Prior to this, the only '70 RAIV Bird Stocker I'd ever heard of was the one Scott Burton built.
Would love to have pics & info for this Bill Kissinger '70 RAIV T/A.
Old 08-29-2020, 05:27 AM   #594
oldskool
oldskool's Avatar
At the Beech Bend div 3 race, 2 of the 10 sec Bird Stockers qualified #17 & #18. They were driven by Chris Stephenson & Julie Biermann.
https://www.dragracecentral.com/DRCS...er=30#indextop
Need to ask a question here. On that list, #72 is Travis Buth, listed driving a '70 GTO. The only '70 GTO Stocker I know of has been driven mostly by Todd Kuhn & Allen Hollingsworth. So, is this the same car ? And, who actually owns this car ?
Just trying to get all the facts straight.
Name:	1 - Chris .jpg
ID:	55424   Click image for larger version
Name:	2 - Julie .jpg
ID:	55425   Click image for larger version
Name:	3 - Todd .jpg
Old 08-31-2020, 06:42 PM   #595
oldskool
oldskool's Avatar
Just discovered this. Don't think it's been included in this thread. But, if so, once again I'll stand corrected.
I thought the only '74 GTO Stocker in div 5 was the one that Brad Koivisto drives. But, this Q-list from last year's Lucas Oil Nats also shows a '74 GTO which is driven by Denny Nelson. Brad's '74 GTO is on the same list & the 2 cars are running different classes.
What triggered me searching for this was that while searching a Pontiac forum for something else, I ran across this link to a Class Racer thread, which mentions several '74 GTO's.
http://classracer.com/classforum/sho...t=46501&page=4
The original owner of the car Denny Nelson has, said he bought the car new, raced it 'til '92, then sold it to Larry Maxwell. It was the car I covered named "Git-Go".
I thought the thread was very interesting, since it mentioned several '74 GTO's.
https://autoimagery.photoshelter.com...IX1JjU-&GI_ID=
Name:	1 - Git-Go .jpg
ID:	55431   Click image for larger version
Name:	2 - Larry Maxwell .jpeg
Old 09-02-2020, 04:16 PM   #596
oldskool
oldskool's Avatar
Since it's US Nats time again, there are some Pontiac names that come to my mind, from the early days. Some are: Jim Wangers, Lloyd & Carol Cox, Mickey Thompson, Don Gay, Mary Ann Foss, Truman Fields, Al Vanis, Rock Running, Roy & Mike McKinney, the White bros, John Clegg, & Mick Leiferman, among others.
https://www.sema.org/sema-news/2010/...liminator-1960
Name:	1 - '60 Nats Wangers .jpg
ID:	55456   Click image for larger version
Name:	2 - Mr. Stock Eliminator .jpg
ID:	55457   Click image for larger version
Name:	3 - A-FX Lloyd Cox .jpg
Name:	4 - Carol Cox Indy Class Win .jpg
ID:	55459   Click image for larger version
Name:	5 - Mary Ann .jpg
ID:	55460   Click image for larger version
Name:	6 - US Nats Win '73 .jpg
Name:	7 - Al Vanis .jpg
ID:	55462   Click image for larger version
Name:	8 - '77 Indy Win .jpg
ID:	55463   Click image for larger version
Name:	9 - Mick @ 77 US Nats .jpg
Old 09-10-2020, 03:19 PM   #597
oldskool
oldskool's Avatar
Posted a pic of this Weidner Pontiac '68 Ram Air II Bird.
While searching for something else, I just ran across this statement. If I've already posted it, just forgive & move on.
"...Special ordered by Weidner Pontiac in Mansfield, Ohio and campaigned by the dealership owner’s son, Pete Weidner Jr. in NHRA’s B/Stock Automatic class during the 1968 drag racing season. It was raced for only one season..."
I've noticed that since they moved these Pontiac threads to the Nostalgia section, I get very few answers to any questions. For most questions, it's total crickets.
It's like very few guys ever even look in this section. Maybe the powers that be got tired of seeing these Pontiac threads keep popping back to the top, in the Stock/SS section.
Oh well, I enjoyed lookin up all the info & learned a LOT I didn't know, from guys who actually saw these old Pontiacs race, & from some who actually raced 'em.
So, to all who have contributed to these Pontiac threads, THANKS ! I really appreciate it !
Name:	Weidner RA2 Bird .jpg
Old 09-15-2020, 11:21 AM   #598
oldskool
oldskool's Avatar
The Biondo '77-'78 Firebird Stocker has been around for quite a few years now. I know for sure that Peter & Sal both drove it some. Don't have a clue how many different drivers the car has had.
But, this past weekend, Dylan Biondo was the driver. He had a pretty good weekend. He was R/U in the 2nd chance race, & on Sunday, he won the bounty for eliminating Saturday's race winner.
Maybe Dylan will be the next Biondo driving star.
Also noticed that "Hatari!" is on the Bird. So, I assume that Phil Monteith had a hand with the engine in the car.
Name:	1 - Dylan RU @ '20 CRN 2nd Chance Race .jpg
ID:	55777   Click image for larger version
Name:	2 - Dylan Won Bounty Hunter Award .jpg
Old 10-05-2020, 07:59 AM   #599
Alan Nyhus
Liked 800 Times in 237 Posts
Norm Warling was running the 421-405 combo in E/SA last weekend at the MCR event in Kearney, Ne.
"That'll never work....."
Old 10-20-2020, 09:35 AM   #600
oldskool
oldskool's Avatar
Some videos were posted in the Stock/SS section. They feature mostly Ford, Mopar & Chevy. BUT, I'm glad I scanned 'em. There are some Pontiac Stockers, which I don't think I've seen in action.
This 1st one is from the Spring Vegas race, in 2002. The 1st pair of cars on it includes the Mulry/Aceves '74 Formula, with Bob Mulry driving. As I've mentioned, this car was a record holder in 3 different classes. It was #1 qualifier at lots of races, & ran more than 1.5 sec under, at several races.
At about the 7:35 point, there is a black '67 Bird. It was driven by Rod Keeney. IIRC, this is the same car that Randi Lyn Shipp has been driving, for several years now.
This 2nd video is from that same race. @ about the 2:55 point is Larry Maxwell driving his '72 Formy. @ about the 3:57 point is Rod Keeney's '67 Bird again. @ about 14:06 is Larry Maxwell again.
Here's the Stock Q-list from that race.
This 3rd video is from the 2003 Summit Nats. @ the 1:56 point is Rod Keeney again.
@ the 9:41 point is John Schloe driving his '69 Bird. As far as I know, it's the only '69 Bird Stocker still active, today.
Here's the DRC Q-list from that race. There were several Pontiacs on the list.
Here's one from the 2001 Summit Nats. @ the 10:34 point is Scott Burton blasting off, in his early 2nd gen Bird. He ran this car as several different year models. The last, of course, was a 1970, which became the quickest Pontiac powered Stocker, ever.
@ this race he was running it as a '73 model, in G/SA.
