Old 10-26-2020, 08:12 AM   #21
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
Default Re: Not for Nuthin' But Close!
I just pulled up a HP Tuners file for that engine combination and body. the speed limiter is active at 106 MPH and turns back on at 104.
very basic ECU and should be very easy for you to come up to speed.
Most notable the Torque table limits in 4 gear. There are no COT or Cat Over Temp in this ECU.
Your rev limiter as 6500.
Could be a little in the shift scheduling also.
I have my own chassis dyno that I do some work on the side so I play with some of the late model flash ware like the HP Tuners.
Great project! Good luck.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 10-26-2020, 12:17 PM   #22
Originally Posted by Marty Knox View Post
What about using an aftermarket computer? Is it hard to put in everything you need?
Marty, You've got to re-read the title of this thread . LOL
Old 10-26-2020, 08:25 PM   #23
Marty Knox
Liked 44 Times in 19 Posts
Mark, I've never priced an aftermarket computer.
How much do they cost?
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 10-26-2020, 08:53 PM   #24
I have no idea ;-)
Old 10-27-2020, 12:48 AM   #25
Billy, That gas is kinda expensive for this program , isn't it?
Do you use it in anything else ? How much , per ?
Old 10-27-2020, 07:33 AM   #26
Billy Nees
No, not at this time but I might try it in some other stuff. Depending on where you buy it, it's no more expensive than supreme.
I wanted something without a really high octane rating to start out with because I can't do anything about advancing the timing... yet.
Billy Nees 1188 STK, SS
Old 10-27-2020, 10:00 AM   #27
Robin Lawrence
Sponsor
I have no idea ;-)
Well I have a little experience in this area. One option is what I mentioned earlier about a flashware product such as HP Tuners. Link to hardware. https://www.hptuners.com/mpvi2/
The hardware will set you back about 300 plus another 100 for the license to modify the file. Once that is done you can reflash or tune as many times as you wish. You will need a laptop computer also.
There are a ton of Stand Alone ECU's out there. Some are fairly powerful and others can be very simple. I can only speak for the Holley since it's what I do.
A Terminator X Holley (low cost system) can be had for about 1000 and includes the harness. Here is the issue, unless the 2.2 uses a common crank pattern like 4X on Crankshaft then you won't be able to trigger the ECU. As simple as your deal is I would work with the stock ECU. It is speed density and has a VE table. It's so very basic, just tune the VE table (fuel) and timing.
Robin
STK 308
SS 3088
Old 10-27-2020, 12:04 PM   #28
Billy Nees
Thanks Robin for your input. HP Tuners is the way that I have been leaning since I started this project. When you're dealing with an nonredeemable vehicle, cheap is good.
Old 10-28-2020, 08:58 AM   #29
Signman
Liked 269 Times in 99 Posts
This looks like great fun!
Love it!
There are plenty of cheap laptops out there. Check out Microcenter for refurbs. They usually have a few with small HD for 200-300 sometimes cheaper.
I have a good WIN XP laptop but think the HP Tuner Software wants a newer operating system. It's important to check what type of cable is included with HPT. If it's serial you either need an old laptop or a gender changer of the right type. If it's USB you should be good to go.
Old 10-28-2020, 12:30 PM   #30
Marty Knox
It looks like with HP tuners the Transmission Control Module program has to be bought as well. I am sure you will want to adjust the shift points.
Marty Knox 3071 STK
