Old 12-10-2020, 06:29 PM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Edge Mustang SS/BX TK or roller
Round tube C-moly back half and cage, Rick Jones C-moly four link , single Adj. front struts, double Adj. rears. Mark Williams Alum driveshaft, Alum center, (bolt thru) gun drilled axles. Strange brakes front and back, 2 new XS 16 volt batteries (2019) new cam lock belts (punched Dec. 2020) Aeromotive A 1000 fuel pump and regulator. RPM performance data-logger ARC touch pad with relay center, MSD ignition. 265 ci. Ford Motorsport V6 with dry sump, Sheet metal manifold with 4150 and Dominator tops (both carbs go with car) Motorsport crank , Crower steel rods, T&D rocker shaft system, low runs on engine. Currently runs 7-8 under requires minimal maintenance. Pro-flite trans (clean neutral) PPP air shifter A1 converter. Ready to race, 30,000 , roller 20,000. I have MANY V6 parts, including a fresh set of heads that made 650 horse in a 278 ci engine, buy some or all of what i have at an additional cost. Cannot get my pics to load but can send in a text or e-mail. fordracers@aol.com or Four, One, Nine,345, Nine, Five,Two, Four.
Joe Buchanan SS/BX 3117
Old 12-20-2020, 12:46 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Edge Mustang SS/BX TK or roller
Joe,
I have a customer that is interested in your car.
I've left a couple messages for you.
Adger Smith (Former SS)
Search this Thread:
Advanced Search
