Old 10-20-2020, 08:08 PM   #21
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Default Re: Trailer tires
The Hercules H901 12ply has a 75MPH speed rating.
NSSGTO is offline   Reply With Quote
Old 12-26-2020, 11:01 PM   #22
Tom O
Liked 151 Times in 36 Posts
Hey Drew, I've had no problems so far with Carlisle load range E 15",(Tire buyer.com 75/80 bucks). 24'ATC w3600# stocker,like Brandon's ,guessing total weight 7-8000 lbs. Been thru GY marathon"s (lots) Tow Max etc.,if your not traveling far D1 should be ok Jmo.
Tom O is offline   Reply With Quote
Old 12-28-2020, 10:36 PM   #23
BTR69
BTR69's Avatar
Liked 90 Times in 27 Posts
Originally Posted by SST159 View Post
Thanks everyone for the input.
definitely a lot to think about.
IMO because most trailer and RV tires are throw away after 4-5 years if you want to avoid blowouts and flats. The question arises do I really need a top shelf expensive tire if they go in the trash in 4 years.
I was fortunate enough to get 7 years out of my Hercules however I have not been doing the traveling I used to do. I keep the tires covered when parked and keep checking the tread for cracks.
I like the idea of the F load range which I believe helps the side walls however I wonder what the speed rating is on those type tires or are they more for HD farm type applications or are they good for higher speed ratings (70-75 MPH)
The tire company I use tells me the Carlisle tire has improved a lot and are proven to be a good grade tire in the E load range. The Hercules also are good in that range as well
The good year endurance, I like the speed rating as others have mentioned but wonder if you are just paying for the name?
Looking at the Hercules site, the ST225/75R15/12 is is the only option for 15" and has a speed rating L, rated for 75mph. The 16" has 3 size options, all speed rated L and load rated G. Appears to have excellent reviews as well.
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 01-11-2021, 11:17 AM   #24
NSSGTO
NSSGTO's Avatar
You won't be disappointed in the Hercules 225/75/15 12ply. Made a huge difference on my ATC 28ft.
