Old 01-13-2021, 10:25 AM   #1781
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: H-I-J '76 Nova re-fit.
How'd Jim do on those heads?
Old 01-13-2021, 10:57 AM   #1782
Nmbr1GMfan
Jim who?
Todd Greene
Old 01-13-2021, 12:23 PM   #1783
Nmbr1GMfan
Trying a different lifter this time.
Todd Greene
Old 01-14-2021, 09:33 PM   #1784
Nmbr1GMfan
I'll assume I'm not the ony person that does stupid sh!t. I usually do this when I just don't know any better, not because I don't care to do it properly. So on that theme, I've recently learned that it's not a wise move to use a tool steel lifter on a billet core cam... aparently the lifter needs a DLC coating or something-er-other. So this is what the lifter will look like if you do it wrong, sort of looks like its cracking on the surface then pulls what looks like metal slivers off the lifter. DO NOT TRY THIS AT HOME!
Todd Greene
Old 01-14-2021, 10:15 PM   #1785
Nmbr1GMfan
We've had a bit of an issue breaking the lower o-ring on the distributor so I went in and gave the block a little more taper. Then wash wash wash!
Todd Greene
Old 01-15-2021, 10:58 AM   #1786
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by Nmbr1GMfan View Post
.....I've recently learned that it's not a wise move to use a tool steel lifter on a billet core cam... apparently the lifter needs a DLC coating or something-er-other.
Good catch, Todd. -Al
"That'll never work....."
Old 01-15-2021, 11:07 AM   #1787
Nmbr1GMfan
I only caught it after I tore something up hahaha.
Todd Greene
Old 01-15-2021, 03:53 PM   #1788
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
I have heard not to use a tool steel lifter on a steel cam, but never saw what happens if you do. Treated and coated lifters would be the answer. What did it do to the cam lobe? Also, do you suppose that those used steel lifters could be coated? Might pay to find out.
Old 01-15-2021, 05:57 PM   #1789
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
I have had a set of tool steel lifters repaired. you should be able to then coat them.
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 01-15-2021, 09:12 PM   #1790
Nmbr1GMfan
Cam isn't hurt, I think I got it just before it really started to do some real damage.
Todd Greene
