Old 01-14-2021, 06:44 PM   #181
J&S Racing
Liked 327 Times in 87 Posts
Default Re: 69 Camaro B/S
Can the drive shaft bounce around on the bent tube under the shaft and contact the fuel line, if the u-joint fails? Did the car have a four link in it at one time. Nice looking build
Good catch, I’m gonna have to play around and see.
That bar is actually part of the frame connectors. I’m sure it’s completely overboard but I set out to make the chassis stiff as possible.
Old 01-14-2021, 11:59 PM   #182
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
What about making a rear driveshaft loop off of that bar?
Very nice build by the way sir.
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 01-15-2021, 06:09 AM   #183
J&S Racing
Thank you.
That’s not a terrible idea. There is another cross bar at the front of the frame connectors and the front driveshaft loop is built off of that.
Old 01-15-2021, 10:02 AM   #184
Liked 11,030 Times in 2,266 Posts
I never thought about connecting the frames left to right. But there is a bunch of stuff that I’m not smart enough to think of. A cage got ours stiff. I may have to make something and see if it helps. Thanks for sharing
Old 01-18-2021, 04:17 PM   #185
J&S Racing
Got the 2nd set of lowering blocks installed today. While I was down there I decided to check on the drive shaft vs fuel lines and thankfully this is close as it gets.
Here is a picture of frame connectors. I did get the ok from D1 tech on this. I still have mix feelings about it. It’s definitely overkill and way heavier than I expected. I do like how the drive shaft loop is part of it. Maybe down the road I’ll have one fabricated from CM to loose some weight.
Old 01-20-2021, 06:00 PM   #186
J&S Racing
Today I got the car on the scales....looks like I can make A... I’ve got some options to move weight around but what do you think??
Old 01-22-2021, 02:13 AM   #187
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Is that with you in it? Can’t wait to see it run!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-22-2021, 06:08 AM   #188
J&S Racing
Yes just short fuel
Some weight installed in trunk
Old 01-22-2021, 07:07 PM   #189
Keith Bennett
Very nice build, I also cannot wait to see it run.
Old 01-22-2021, 08:52 PM   #190
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have a chassis stiffener like yours on my '68 Mustang. Definitely tightens up the frame. Mine is from Total Control, a part of Chris Alston's ChassisWorks. Where did you get your unit?
Dale Shearon
68 Mustang 6394
