Old 01-10-2021, 09:51 PM   #31
doglover44
doglover44's Avatar
Liked 492 Times in 230 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
How good are the Calvert shocks?
Jake Biermann
doglover44 is online now   Reply With Quote
Old 01-16-2021, 02:11 PM   #32
J518
Liked 151 Times in 37 Posts
You'll have to check back in, in a few months!
J518 is offline   Reply With Quote
Old 01-23-2021, 07:30 PM   #33
J518
Instead of watching it snow I decided to get some pre planning done....Here is an electrical print I made. Seems to simple, feels like I am missing alot. Let me know!
Old 01-23-2021, 11:07 PM   #34
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Your starter wire looks like it's on the battery side of the cut off switch. That would leave a hot wire under the hood after the kill switch was thrown.
I'm a little confused here. Looks like two of stuff like fuel and water pump?
Remember that each of those relays has 4 terminals. You need 12 volts in, 12 volts from the switch to trip it, a ground and a wire to provide the power to the accessory.
EDIT Not two pumps, two relays. One looks like it's on the power side and one on the ground.
Dale Shearon
68 Mustang 6394
Old 01-24-2021, 10:22 AM   #35
J518
Yeah i think i have you confused because the symbol for a dc motor and a dc relay coil are the same. I will nomenclature them better to keep everyone from getting them mixed up
Old 01-24-2021, 02:13 PM   #36
Greg Reimer 7376
Liked 719 Times in 220 Posts
https://i.postimg.cc/cLvpbsJ4/IMG-0137.jpg
I love the car but couldn't help but notice how well organized your garage is, LOL.
You can either have a well organized garage or one where stuff gets done.
Old 01-24-2021, 02:59 PM   #37
FireSale
FireSale's Avatar
I'm interested in following this, so a new diagram would be appreciated. I wire stuff myself and always use too much wire but everything works. I make extensive use of relays.
Is your cut off switch external? If so the only way to kill power to that main distribution block is from the outside. There should be a master cut off within the drivers compartment to shut stuff down on one switch. I've used a push button 100 amp breaker - the big black things - for this. My main power now runs through a high amp continuous duty solenoid. A toggle switch activates it to apply power.
Dale Shearon
68 Mustang 6394
Old 01-28-2021, 07:35 AM   #38
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
you have a PM. thanks
Old 02-01-2021, 02:51 PM   #39
J518
Snow slowed us down but we were able to wrap up the brakes lines this weekend.
Old 02-01-2021, 02:56 PM   #40
J518
REAR
