Old 02-01-2021, 02:59 PM   #41
J518
Liked 151 Times in 37 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
We were also able to "seal" off the drivers compartment from the trunk. Now we will begin mounting/routing the fuel cell.
J518 is offline   Reply With Quote
Old 02-14-2021, 04:06 PM   #42
J518
With the crazy cold temperatures rolling through, about the only thing I could do was get started on the wiring. You'll see I updated the print with some revisions. One in particular being a DPDT relay added to latch the line lock on for staging purposes and releasing once the clutch is released. This also allowed me to wiring in the burnout rpm separate from the launch rpm.
All electronics will be where the glovebox was.
Old 02-14-2021, 04:09 PM   #43
J518
Now if I could only hide the 30 wires from the grid that I won't be using.....
Old 02-14-2021, 05:39 PM   #44
a pontiac
Liked 36 Times in 11 Posts
I think you need 2 bars running from the top of main hoop to the rear frame. I maybe wrong might check rule book.
a pontiac is offline   Reply With Quote
Old 02-14-2021, 06:39 PM   #45
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Looks nice. Now that I see the photos of your electrical layout everything makes sense. Good luck fitting all this stuff in your glove box with room for expansion. I tried that with my Mustang and wound up with a panel on the passenger side foot board. But that's a Ford....
Keep up the good work.
Dale Shearon
68 Mustang 6394
Old 02-14-2021, 06:59 PM   #46
FireSale
FireSale's Avatar
I checked back in the book (I run a 10 point cage), and this is correct. This car has the crossbar angle braced but not the top hoop. Here's a pic from the 2020 book:
Name:	STOCKER ROLLBAR.png
Dale Shearon
68 Mustang 6394
Old 02-17-2021, 02:33 PM   #47
J518
Thanks guys. Looks like you're correct. We'll add it to the list!
Old 02-21-2021, 12:05 PM   #48
J518
Stick Shift Necessities!!!
Old 02-21-2021, 12:16 PM   #49
J518
Looking back, can't believe we missed the main hoop support bars but thankfully it was brought to our attention before the interior was in.
So thank you!
We made quick work with a saturday afternoon and added two bars.
Old 02-21-2021, 12:19 PM   #50
J518
To wrap up our afternoon we settled on our fuel cell location. Made our fuel cell band before running out of enough material for a on the second one.
