#191 | |
wound up being a major PITA to make right. Removing the booster made the car difficult to stage even for Doug so I've spent the last couple of days "re-engineering" the stock pedal assy. The OEM assy. is quite complicated so I went to my favorite place (junkyard) and got another Cavalier assy. and an 80s Camaro assy. and "blended" the two together. I now have a 6-1 pedal ratio (OEM was between 3+ 4-1) and a nice feeling brake pedal. My plans for this week are to build a couple of different collectors and see if I can make the header work a bit better.
#192 |
Liked 869 Times in 165 Posts
Here are some pictures Billy sent me to upload on here.
#193 |
Hey all you Mopar guys! Check out the Neon (with chute) that was stalking us all day.
#194 |
Liked 5,138 Times in 1,961 Posts
Billy, You should have just ordered those brake parts @ Summit or Jegs
#195 |
What front tires are those? Are they Circuit Racing Slicks?
Billy Kirpens Jr / Pro ET / Street ET 123J @ Lebanon Valley Dragway Stock/Super Stock 123A |
#196 |
I would guess that they are some sort of an asphalt "circuit" slick. Hoosier 19.5x7-13.
#197 | |
The brakes worked out great! Doug could hold the car at 3 grand if he wanted to. I built 2 different collectors for the car. The original one was 2 3/4" dia and about 15" long. I built one 2 1/4" and 15" and a second 2" and 24" planning on cutting it down. I don't have my timeslips and notes with me but we made 7 runs all between a 15.25 and 15.28. Not too bad for changing things between runs. It wasn't a very good day, low baro., high humidity and head wind but at least the sun was shining. As I changed the collectors, we started to see a pattern develop. It went it's best MPH (by 1 full MPH!) with the 2" collector cut to about 10" long but it went it's best ET (15.25) with the original collector. This past week, I was able to find some specs on the original cams and although they're both very small, the exhaust cam is really small. I'm starting to think that the restriction that is cast into the original exhaust manifold is there for a reason (duh, gee do ya think?). At any rate, Comp DOES make a "streetable" cam set that is a bunch bigger than the original ones and is under my .430 lift limit. I guess that I've got to buy some cams.
#198 |
Liked 735 Times in 386 Posts
Billy,
Since it is DOHC. Have you thought about playing with the phasing of each cam before you try new cams? Unlike a single cam setup you can change LSA / overlap. Stan |
#199 |
Yes, I have and the exhaust lobe is seriously retarded. If there wasn't anything commercially available, I would have "played" with moving the existing cam c/ls around. It does need (at least) a larger exhaust lobe.
#200 |
Billy,
Thanks. Maybe I have confused this with one of your other threads. I was thinking this was as low a $$$$$'s build as possible. Stan |
