Old 03-21-2021, 10:30 AM   #31
Rory McNeil
Liked 1,103 Times in 301 Posts
Default Re: It's About Time (Not MPH)
Mark, good time to upgrade those hub bearings to some nice, low drag ceramic pieces!$$$
NHRA 6390 STK
M/S 85 Mustang
Old 03-21-2021, 11:43 AM   #32
Liked 5,114 Times in 1,948 Posts
Yep... They'd fit right in on this project
Old 04-28-2021, 12:29 AM   #33
Almost time for smoke in the pipes...
Old 04-29-2021, 07:38 PM   #34
HP HUNTER
Liked 372 Times in 129 Posts
Looks great!
Old 04-29-2021, 09:11 PM   #35
Rory McNeil
Nice progress, Mark. Header looks great. I`m guessing the water pump needs to driven off the timing belt, so no way to run it electrically?
NHRA 6390 STK
M/S 85 Mustang
Old 04-29-2021, 11:52 PM   #36
Um, no not really .The former water pump is now an idler pulley.
The Motorcraft PW 611 electric pump is going into the lower hose.If it's good enough for the 2016 302 Cobra Jet, then it's good enough for me. Going to match up a bottom hose tomorrow and then build a bracket to hold it. No, you can't buy one at Jegs or Summit.. ;-)
Pics to follow.
Old 04-30-2021, 03:39 PM   #37
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Pics to follow.
It's been a while since I looked at rule book. Has the rule changed on this?
It used to read "Electrically driven fans and water pumps permitted. Water pump must bolt on, with no modifications to block."
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 04-30-2021, 05:07 PM   #38
SSDiv6
Liked 1,577 Times in 581 Posts
This particular water pump is an OEM water pump and does not require any modifications to the engine block.
SSDiv6 is online now   Reply With Quote
Old 04-30-2021, 07:34 PM   #39
jimmyparker
Liked 309 Times in 88 Posts
Mark, great detail work.
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 05-14-2021, 10:51 PM   #40
Please see my post in S/SS Tech ..EFI Help Needed
Thank you.
