Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 04-02-2021, 11:18 PM   #1
rod
Liked 20 Times in 15 Posts
Default wire feed welder ?
I have HF AC welder. it splatters. does the DC welder do more or less?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-05-2021, 09:42 AM   #2
novassdude
Liked 136 Times in 49 Posts
Default Re: wire feed welder ?
Is it a wire feed? Solid wire or Flux core? or Stick welder?
novassdude is offline   Reply With Quote
Old 04-05-2021, 09:11 PM   #3
rod
it is an AC flux core wire feed. welds good for what I do. just lots of berries
in corners or tight areas.
Rod
Old 04-05-2021, 09:14 PM   #4
There are better grades of flux core wire..Hint: Don't use the stuff that comes with it.
Old 04-06-2021, 10:15 AM   #5
1matcoman
1matcoman's Avatar
Liked 357 Times in 138 Posts
Thumbs up Re: wire feed welder ?
^^^ this !!!
Old 04-06-2021, 10:37 AM   #6
novassdude
Rod
I am far from an expert but I know on mine (Century welder) using flux core I always get a good amount of splatter. Same welder using gas is much cleaner. I never did try different brands of wire.
Old 04-07-2021, 10:24 AM   #7
SSDiv6
I have a Century (Lincoln) Flux Mig.
Like Mark said, the amount of splatter depends on the brand of the wire. I only use Forney and Lincoln and the amount of splatter is minimum.
Old 04-07-2021, 04:00 PM   #8
4ktowman
Liked 63 Times in 2 Posts
I have used anti splatter spray helps a lot to clean splatter off ...plus smells like frying fish when welding...lol
4ktowman is offline   Reply With Quote
Old 04-14-2021, 11:25 PM   #9
rod
I noticed, the other morning when welding, in areas when it is hard to get the nozzle just right, there was more splatter. and in an area, where 'everything was perfect' way less. and that was one why I asked. inside angle iron corners seem to be bad. guess it because of nozzle position.
not to cause hard feelings, but...have you ever looked at harbor freight flux wire and then looked at forney. exactly the same. except HF is way cheaper. just sayin'.
thanks Rod in AZ
Old 04-15-2021, 12:42 PM   #10
SSDiv6
thanks Rod in AZ
They may look the same, however, the composition is different.
