Old 03-30-2008, 04:02 PM   #1
sc321
Default Low sulfur diesel fuel
With the low sulfur diesel fuel currently available does any one add anything to the fuel to increase lubrication and increase mileage? I have heard due to the low sulfur and lubrication properties addatives are required. Towing with a 300hp cat in FL.
sc321 is offline   Reply With Quote
Old 03-30-2008, 06:26 PM   #2
Brian Hansbury
Brian Hansbury's Avatar
Send a message via Yahoo to Brian Hansbury
Default Re: Low sulfur diesel fuel
BG products makes a full line of conditioner and cleaners www.bgprod.com you can find a dealer near you
Brian Hansbury is offline   Reply With Quote
Old 04-10-2008, 10:25 PM   #3
NED890
synergyn racing oils just came out with a new product for diesel and it seems to work very well.give me a call and i can give some info on it thanks 609 490 0643
NED890 is offline   Reply With Quote
Old 06-16-2008, 08:09 PM   #4
1968chevelle
Here in WV we have had a lot of pluged fuel filters from 'geling' of the new fuel, they tell me you need to run a additive, I have been useing amsoil and have had great luck with it.
1968chevelle is offline   Reply With Quote
Old 06-16-2008, 10:12 PM   #5
luckydog
luckydog's Avatar
I've been told by multipule people and read a topic on drr about using ATF or 2-cycle. I guess it lubricates well and improves mileage.
Damien Hazelton
Lucky Dog Racing
luckydog is offline   Reply With Quote
Old 06-17-2008, 12:01 PM   #6
1968chevelle
If one mixes atf or 2-cycle, that will change the color (I would think) so would add a trace to make the DOT think there was a trace of off road fuel, that could make for a costly ticket. Other than that Id say it would work good.
Old 06-17-2008, 04:22 PM   #7
luckydog
luckydog's Avatar
I too thought of this. For 1 I think you only add 1 quart of ATF per 25 gal of fuel so I don't think it would discolor it too bad. Also, I think before they could give you a ticket they would have to test it, especially if you claimed it was ATF or 2-cycle. I don't know?
Damien Hazelton
Lucky Dog Racing
Old 06-17-2008, 06:20 PM   #8
Chuck Westcott
Chuck Westcott's Avatar
I've been burning it since it hit the pumps and I haven't seen any difference except the PRICE.
Temps are the same and so is mpg - 7 with the trailer and 9 with out.
Last year I burned a few thousand gallons.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 06-17-2008, 06:44 PM   #9
BOO BOO
Had fuel filter problems also, now my generator filter was messed up with less than 200 hours on it.
Chuck Siegler
BOO BOO is offline   Reply With Quote
Old 06-17-2008, 06:50 PM   #10
Chuck Westcott
Chuck,
I change all my filters every 10K miles, maybe you got some bad fuel.
