Old 05-06-2021, 06:17 PM   #1
e vassar
Liked 272 Times in 108 Posts
Default Liquid teflon or tape?
For my water temp probe fittings in the electric water pump....thanks
Old 05-06-2021, 06:25 PM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Re: Liquid teflon or tape?
Either will work, however the tape is much neater
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 05-06-2021, 06:32 PM   #3
e vassar
Ive always had good luck with tape, but now reading can cause water pump housing to crack.
Old 05-06-2021, 06:54 PM   #4
pmrphil
Liked 348 Times in 152 Posts
Only if you overtorque it. Keep in mind that teflon is a lubricant as well as a sealant.
Phil Molski
PMR Performance
S/C 1623
Old 05-06-2021, 11:11 PM   #5
CMcAllister
Liked 920 Times in 259 Posts
I prefer tape. Neater. And I can control the thickness.
CMcAllister is online now   Reply With Quote
Old 05-07-2021, 10:00 AM   #6
John Dinkel
Liked 263 Times in 68 Posts
I like tape.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 05-07-2021, 01:46 PM   #7
SSDiv6
In the aviation world, the use of Teflon tape is prohibited due to the potential of the tape deteriorating and slivers getting into the fuel, hydraulic or other systems.
Since AN fittings do not seal at the threads, but rather at the flare, mechanically, metal-to-metal, there is no need to use sealant on the flare end.
The only time you need to use sealant is on any fittings with pipe threads. The proper process to use the liquid Teflon sealant is to apply a single bead all around the thread, keeping it away from the first two threads and the end of the fitting. A good indication that just enough sealant has been applied is when a small amount of sealant has been pushed out of the fitting all the way around the threads.
The best fitting sealants that I recommend are Permatex 59235 and Loctite 567. They are fuel, oil and ethanol resistant and great with high pressure plumbing such as brake caliper fittings.
Old 05-07-2021, 03:07 PM   #8
quickford1
Liked 20 Times in 12 Posts
Bingo
quickford1 is offline   Reply With Quote
Old 05-07-2021, 03:13 PM   #9
KRatcliff
Liked 534 Times in 143 Posts
It is easy for me to tell when I put the tape on backwards. A little harder with the liquid.
KRatcliff is offline   Reply With Quote
Old 05-07-2021, 03:18 PM   #10
SSDiv6
LOL! Are we talking about liquid Spirits?
