Old 05-07-2021, 07:59 PM   #1
rod
Liked 20 Times in 15 Posts
Default pinion angle?
put on a set of Cal-Tracs. need to know what is the best pinion angle?
Specs. 56 Nomad, leaf springs [6 'cause its a wagon] spring pads are 6" long. 9/16" U-bolts. approx. 1725lbs on rear. motor mounted solid, so the trans angle is NOT adjustable.
right now the 4speed to 'shaft is 2degrees. the pinion is about 1/2degrees up from level and there is 2 degrees difference.
I have degrees shims. if I put the pinion down -2degrees, that would make 4 degrees total at the rear. setting the front would change very little. at launch, the front angle should increase approx 2 degrees [front/body rise].
in high gear the front drops down. in theory then, the front angle would be 2+ degrees difference and the rear would be 2 1/2 degrees the opposite direction. sound right or no?
with the long spring pads, I cant see the pinion turning up very much. 6degrees down would be a lot, I think!
thoughts?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 05-07-2021, 08:55 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: pinion angle?
What you want is about 2 degrees down between the pinion and the driveshaft angle. That way under power the angle will be near zero.
Mike Pearson 2485 SS
Old 05-08-2021, 08:53 PM   #3
rod
there is no good place to place the magnetic angle finder on a 9". so I made a 5" tab, which uses 2 studs on the pass. side. now, I get 1 1/2 degree up.. so using a 4 degree wedge, I should get 2 1/2 degrees down.
will post real measurements when finished next week.
Rod in AZ
Old 05-09-2021, 08:14 PM   #4
Eman
Liked 133 Times in 76 Posts
My way of doing it has the driveshaft out of the car. Car sitting on boxes so the chassis weight is on the tires. Have the pinion yoke turned so you can measure off of the flat of the yoke. Place angle finder on harmonic balancer, then place it on pinion yoke, difference is pinion angle.
Old 05-09-2021, 08:37 PM   #5
jbt352
Liked 2 Times in 2 Posts
Eman this is the simplest way to do it. Too many people over think it.
jbt352 is offline   Reply With Quote
Old 05-10-2021, 09:16 PM   #6
fordteacherguy
Liked 160 Times in 51 Posts
Smile Re: pinion angle?
BTW: You can download the Tremec Driveshaft Angle Finder tool for your phone on Google Play...FREE! Useful at the track....or at the shop. Accurate to .1 degree...Works on Android systems..
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 05-10-2021, 09:57 PM   #7
Dana Fitzpatrick
Liked 10 Times in 6 Posts
That's the way John Calvert taught me.
Dana Fitzpatrick is offline   Reply With Quote
Old 05-11-2021, 07:26 PM   #8
CMcAllister
Liked 931 Times in 265 Posts
Doesn't tell you the operating angle of the front and rear u-joints, which could be quite different car to car depending on location of engine/trans assembly, ride heights, length of the drive shaft, pinion height in the rear, etc.
I want to know the operating angles of both joints. Rare to have the desired configuration of the front joint near zero and rear joint at the desired number down (negative).
