Old 05-11-2021, 05:25 PM   #1
ImBack
Liked 5 Times in 4 Posts
Default Rpm Switch
Going to order a turbo action shifter and air shift solenoid for my S10 ,was wondering if I should keep the m s d RPM activated switch or if I should switch to one of the digital delay rpm switches?
ImBack is offline   Reply With Quote
Old 05-11-2021, 06:49 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Rpm Switch
I had MSD RPM switches and on data logger it was showing up to 100 rpm difference. Changed to dual rpm Biondo box and shift points stay the same
Jeff Stout is online now   Reply With Quote
Old 05-11-2021, 08:53 PM   #3
ImBack
Thanks,I'd heard the same even worse variance from 1 guy.
Old 05-12-2021, 07:53 AM   #4
curtis reed
Liked 125 Times in 59 Posts
I have started using this switch and really like being able to shift on rpm or time.
curtis reed is offline   Reply With Quote
Old 05-12-2021, 08:01 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
I use the RPM activated switch from MSD to activate my shifter. I have found them to be very accurate. I only make one shift though.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-12-2021, 08:52 AM   #6
Dragsinger
Liked 99 Times in 60 Posts
The above-listed Elite controller from Digital Delay is a good product. Very accurate.
Larry Woodfin 471W
Old 05-13-2021, 12:26 PM   #7
ImBack
Thanks alot guys,buying that 0ne!
Old 05-13-2021, 05:15 PM   #8
ImBack
Thanks a lot guys I ordered the turbo action reverse pattern air shifter, the air shift solenoid, the digital delay elite switch, time or RPM and a air shift bottle and regulator all from Biondo.. Apparently I got the last reverse pattern Turbo Action Air shifter in the United States, according to Turbo action they didn't even know they had one in stock but they had 1... otherwise mid-july
Old 05-14-2021, 07:45 AM   #9
curtis reed
You will love that switch. I race a roadster in Footbrake. Last weekend I was racing Footbrake and 6.0 Index. I could switch back and forth from rpm shift in Footbrake to time in 6.0
I have to slow the car way down in 6.0 so I was shifting at .15 and then 7300 in Footbrake. Takes about 5 seconds to change between the two. I trigger the timer to start when the switch sees 4500rpm. You can also trigger it with a push button.
Curtis
Old 05-15-2021, 11:12 PM   #10
ImBack
Thanks for the info!! I was planning on shifting this on time instead of RPM once I get it figured out. I'm glad everyone likes this setup, I'm pretty sure my last shifter problem was due to a MSD RPM switch not shifting twice
