Liked 99 Times in 60 Posts
Racers, I have the conventional compressor with 4 "fingers" that pull the spring together using a long thread rod. The puller is very old [like me a many of my tools] and I am beginning to fear its failure.
I see talk about an OTC tool that has two disks that pulls the spring together. Does anyone use that tool. Or other tools?
Larry Woodfin 471W |
Liked 230 Times in 75 Posts
Yes the OTC one works great, have no fear when using it laying under a car. It doesnt work in every application, but is great when it does. On a side note working on a 74 GTO it wouldnt work used the kind you are taking about but with only 2 hooks and went through shock hole on frame, some one shared trick of putting heater hose on the coil spring to keep hooks from coming off worked well. I think this tip came from Marty.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#3 | |
Liked 439 Times in 69 Posts
Herbie Null 201 SS |
Liked 275 Times in 76 Posts
The OTC tool is the one that Randy Manns suggested for my new springs. They are not cheap, but the safest spring compressor I have ever used. It was money well spent.
Sean
Liked 133 Times in 76 Posts
I have a Snap-On which is a Branick. It has 2 hooks and a slip in fork for the bottom. I've used it on my 3rd gen with Moroso trick springs.
This is the style I have https://www.amazon.com/dp/B08XQVWMN6...=1622175908865 Last edited by Eman; 05-28-2021 at 12:25 AM. |
