Old 04-03-2008, 05:34 PM   #41
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Automatic Horsepower Factoring System
Lynn, Maybe with time Nhra will accept TOP/STK and TOP/SS and a couple wt breaks as Heads up at points meets as well as Opens Then people who like that will have a choice . Dick
Old 04-03-2008, 06:21 PM   #42
Evan Smith
Liked 115 Times in 5 Posts
Jim,
I also think a 2-3 tenth reduction of the indexes is a good answer. I think that is probably the direction that it will go, however, I would like more input, before trying to push something through. But those who I have spoken to so far seem to agree. On the other end of that, I'm sure the very small percentage of racers who are hovering on the current indexes can do some easy things that to find the same 2-3 tenths.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 04-03-2008, 08:21 PM   #43
vic guilmino
Liked 56 Times in 21 Posts
ok put index to -.3
and go back to 1.00 under triggers
Vic Guilmino 1129 STK
Old 04-03-2008, 08:32 PM   #44
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Automatic Horsepower Factoring System
I was around back in the '80's when NHRA added 2 tenths to all the indexes. One reason given by NHRA was because there were always about 4 or 5 racers at the bottom of the ladder that were struggling to be able to run the number and it would also lower the hurdle for new racers to get involved.
After about a year it was the same guys that were struggling to make it under again.
Jim Cimarolli is offline   Reply With Quote
Old 04-03-2008, 09:35 PM   #45
bsa633
Banned
actually i think it was in 93 they raised them...but i am with Jim B. give those .2 back + another one for starters.. .5 would work to even better in the long run! and have a group of individuals(not racers) to manually clear up the the ones that will be to far ahead,,
bsa633 is offline   Reply With Quote
Old 04-03-2008, 09:54 PM   #46
Dick Butler
If the sandbagging and fear of running fast is what people are complaining about how will lowering the index help?Would the trigger be lowered too? Does that do anything? except make a number less under. Does it affect the HP problem some cars show?
Old 04-03-2008, 11:45 PM   #47
SS Engine Guy
This isn't a numbers game in a casino. Lower what ever you want. The fast will still be as far under and the bogus hp factors will still be bogus.
SS Engine Guy is offline   Reply With Quote
Old 04-04-2008, 07:21 AM   #48
Bruce Noland
Liked 444 Times in 145 Posts
Lowering the indexes by .30 is the fair and honest solution for everyone. National events are all run affairs any way.
Bruce Noland 1788 STK
Old 04-04-2008, 09:48 AM   #49
Dick Butler
Bruce, You state lowering the index .3 is the "solution". What is the problem? If it the fear of being factored then yes. If it is to make the Bogus Hp combinations better controlled, NO no effect. Moving the trigger will not effect it either...
The current "problem" appears to be that it does not sort out Fast cars from hard work by extensive numbers of cars and hard working numbers of racers from one off Bogus cars discovered by Book work. Yes theses cars have work too but they start out soft for multiple reasons mainly being just allowed as they are in the book.This needs to be addressed by the Committee.
Require a person to file a letter of intent to run a combo before they dig out the 50 year old 2 x4 manifolds and make a mockery of the factoring system. Common sense initial factoring should be required. The same holds for new stuff with exotic technology allowed as a way to get new cars into the eliminator by unreasonable low expectations on numbers for HP.
Old 04-04-2008, 09:56 AM   #50
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
I am one of those racers that used to be close to the index, and with some work have managed to get faster. Recently I tried some newer components and have managed to get back to square one, only running about 3 tenths under. I know of other racers that sometimes are near the indexes. I DO NOT LIKE THE IDEA OF LOWERING THE INDEXES. It does nothing except help the people that run very fast from getting horsepower. The lowering of indexes was done to bring more people into the category, not to punish people from going too fast. There are so many bogus combos, parts, etc. that need to be addressed first. The AHFS cannot work as long as these things exist. Fast guys are jamming on the brakes to protect their HP, and NHRA keeps telling you to stop it because it is a safety thing. But do they enforce it, NO. I can't tell you how much smoke I have seen comming off the front tires of people trying to make it close with my 14 second slug at the finish line, What happens, they are told "if you do that again we are going to DQ you" Do they ever get DQ'd , NO, it's a bunch of bull. I watch cars from the stands at the finish line and see so much sand bagging it's disgusting. This is a performance based category, and it has turned into a circus. No one wants to go too fast, but they want to be the fastest. A bunch of bull.
NHRA needs to start tracking every run and all incremintal times from the 60' to the finish line to detemine what the vehicles really are capable of. They need to implement a system that accounts for weather and altitude tracks, and I know it can be done with todays technology. They need to start enforing their own interpretation of the rules they made. When some guy out in the middle of nowhere hits your combo with a fast run, you get penalized even though there are differences in the two combos. Is that fair, no a bunch of bull. Someone goes out and goes 1.50 under and is immediatelly hit with HP. Are they torn down first to make sure it was legit? If they are legit then they deserve HP because it was factored wrong in the first place. Superceded parts are another joke, it's given to some but not others, and you wonder why the AHFS is not working. I read where people have a varied view of the way things should be done, lower the indexes, lower the trigger, leave it alone, allow certain things, .50 under to win class, more teardowns, no paper cars, give us more parts, STOP IT.
There is nothing wrong with the current indexes. Eliminate the trigger system, let the fast cars go fast, stop the sand bagging, enforce the rules correctly, this is Stock Eliminator, a PERFORMANCE BASED category. If you want more liberal rules or parts, go to Super Stock.
Ron Ortiz
U/SA .3 under and still competitive.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
