Old 09-21-2021, 12:37 PM   #11
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Default Re: Trans Cert Tags
Certs for Cases and Shields are only good for 5 years. You may want to weigh the expense of a TH400 SFI Case vs a Complete SFI PG if that will work in your car or in the future you decide to shelf the 400. May be happier and save more $$'s ultimately.
SC 707Y
Dano is offline   Reply With Quote
Old 09-22-2021, 09:53 AM   #12
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
The SFI cases are so much nicer to work with, IMO. I don't miss getting to the top bellhousing bolts in my stock chassis Nova while trying to use two long extensions from below and working around/through the shield.
In just a couple weeks I'll be pulling the trans from both of my cars to have them stripped down and the cases sent in for recert, and that does suck a little bit. And when you do that, don't forget to send the steel liner as well! I learned that the hard way my first time.
S/ST 51
S/C 53
Old 09-22-2021, 12:04 PM   #13
Dano
Dano's Avatar
Been there Done that on my 70 Nova also
SC 707Y
