Liked 7 Times in 5 Posts
This might have been discussed previously, but couldn't find anything. I know that staging "skinny" vs. deep staging will change 60 ft times and ET. Some racers have stated that down-track split times will remain the same. In my experience, any slower 60 ft time tends to compound itself going downtrack. Any similar experiences? For example, .015 slower 60 ft. might equal .05 slower ET.
Liked 708 Times in 285 Posts
If the car acts the same then yes 60ft would effect 1/4. Split times should remain the same or very very close. Same for 1/8 mile. We have tested using Dragy GPS and watched 1/8 mile times when going down track and it has shown matching difference
in 1/4 et. Last edited by Jeff Stout; 09-26-2021 at 12:21 PM. Reason: More |
#3 | |
Liked 17 Times in 9 Posts
But if I'm on the stop, my car is closer to a 1:1 ratio. Example, if I slow .01 to 60', then I will be about .01 slow to 1320. I feel the throttle stop kinda resets the run. |
sst5167, thanks! Good info! I don't run my car like most, my T-stop goes to part throttle at the launch and stays at that position for the full run. It kinda makes sense now.
Liked 431 Times in 224 Posts
I think if the car lost 60' because of spin, the ET loss will compound as you go down the track.
If you fully deep stage, your 60' might be .08 slow but your incrementals should stay the same as a shallow run, resulting in a 1/4 mile time that is .08 slow. Not all 60' changes are created equal.
S/ST 51 S/C 53 |
Liked 192 Times in 83 Posts
OOOOOOORRR, you could go to Cecil County where the roll out is set for tractor-trailers, and really pull your hair out.. you stage very shallow, whack the tree, but come up with a really bad reaction time.. BUT, your 60' picks up .06, cause you had a running start at it.. IMAGINE THAT!!
Ain't that right, Tom Goldman??.. Last edited by Charlie Yannetti; 11-14-2021 at 10:09 AM. |
