Old 09-30-2021, 08:44 AM   #1
stock1080
Liked 94 Times in 38 Posts
Default line lock ?
I have a street/strip car. It has a brake pressure relief valve. To install a line lock, before or after the valve? Does it matter? thanks
stock1080 is offline   Reply With Quote
Old 10-03-2021, 09:00 AM   #2
Rory McNeil
Default Re: line lock ?
Are you refering to the factory installed brake distribution block/ proportioning valve usually mounted between the master cylinder and the lines to the wheels? In the past, I have installed several line lok solenoids between the master cylinder and the factory brake distribution/proportioning valve, worked fine, never had any issues. However, a number of years ago, NHRA added a condition in the rule book, that stated any brake solenoids were to be mounted AFTER the valve, before that, there was no mention of allowable locations. I have to assume, that somebody somewhere, must have had the valve stick, causing a crash or front tires not releasing, to make this an issue. So, ever since, I did the extra plumbing to mount the solenoid after the valve, but I personally never noticed any difference in how the Line Lok functioned, either way.
NHRA 6390 STK
M/S 85 Mustang
Old 10-08-2021, 08:26 AM   #3
stock1080
Talking Re: line lock ?
outstanding, thank you very much jeff
