Old 10-16-2021, 04:30 PM   #11
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
More cage/tube work.
Todd Geisler is offline   Reply With Quote
Old 10-16-2021, 04:33 PM   #12
Todd Geisler
Time to move to the rear and work on the backhalf.
Old 10-16-2021, 04:35 PM   #13
jims5600
Liked 21 Times in 9 Posts
Awesome work thus far. The way it is progressing your new ride will be
as good or even nicer than the Malibu was.
Good luck
Jimmy
jims5600 is offline   Reply With Quote
Old 10-16-2021, 04:36 PM   #14
Todd Geisler
A couple key body pieces came in. The front end is carbon fiber from Motor City Solutions. The other piece is an original rear bumper that seems to be as rare as hens teeth. I'm converting the car from a 1989 areo nose to the 85-86 4 eye configuration and stock rear bumpers aren't reproduced and hard to find.
Oh yea, I forgot, the carbon fiber roof skin came in as well.
Old 10-16-2021, 04:41 PM   #15
Todd Geisler
Now was time to move to the front. First up was to tie the lower part of the front frame rails into the floor structure.
After that was done the engine & transmission were positioned so the midplate and motorplate could be fabricated.
Last small item up front was to tie the shock towers in with tube.
Old 10-16-2021, 04:44 PM   #16
Todd Geisler
At this point the major part of the tube work was done and the body needed to come off long enough to weld any area not accessable with it on.
Old 10-16-2021, 04:46 PM   #17
Todd Geisler
Car removed from the table and first time mocking up the suspension.
Old 10-16-2021, 04:48 PM   #18
Todd Geisler
Momentous occasion. First time sitting on 4 wheels since it arrived at my house in stock form.
Old 10-16-2021, 04:54 PM   #19
Todd Geisler
From here on out, the project was just working through one small project after another in which there were many.
First up was mounting the Racetech seat.
Mockup block removed and the engine out of my Malibu set in place.
Hood clearance issue...will get back to that later.
Brake pedal mount.
Removable transmission crossmember and mount.
Front driveshaft loop.
Old 10-16-2021, 04:57 PM   #20
Todd Geisler
Steering column.
Steering linkage.
Chute handle
Throttle pedal recycled from the Malibu
Battery mount
