Old 10-31-2021, 05:43 PM   #161
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Default Re: Project - NHRA Stock and S/S results 61-68
"...PONTIAC:
The Max Sterling picture is not a 62 Cat 421/405sd.
I think that picture in your writeup is a 61, maybe his previous car?..."
Yeah, he had a '61, a '62, as well as a '71 Bird, all named "White Lightning".
May have had others. But I only have pics of those 3.
Name:	1 - '61 White Lightning .jpg
ID:	61049   Click image for larger version
Name:	2 - '62 White Lightning .jpg
ID:	61050   Click image for larger version
Name:	3 - M. Sterling '71 Bird .jpg
Old 10-31-2021, 06:04 PM   #162
oldskool
oldskool's Avatar
"... I have Proffit driving a Chev at Indy 62, even a pic of his car in the winners circle....so not sure why you thought I listed it as a Pontiac?..."
"...PONTIAC – 1962 421 cui Super Duties were produced in enough numbers to qualify for SS/S.
These 421 cui motors ran 11:1, dual quad carburretors and were rated to 405. The lightweight panels were available to the approved teams and raced in SS/S. Hayden Proffitt proved the cars worth by winning Top Stock at the US Nationals..."
I copied & pasted that from your '62 section.
I assume you meant to say the Winter Nats. But, you said the US Nats. The pic you posted shows a '62 with #670 on it. I assume that was @ the Winter Nats.
Yes, Hayden is mentioned driving the Chevy @ Indy, in other parts of the section. But, you obviously made a little booboo, as shown in the part I copied. Easily fixed.
Name:	1 - '62 #670 .jpg
ID:	61052   Click image for larger version
Name:	2 - SS-S 670 .jpg
ID:	61053   Click image for larger version
Name:	3 - 670 SS-S .jpg
Old 10-31-2021, 09:11 PM   #163
DeuceCoupe
Liked 48 Times in 44 Posts
Doggone it all this digging, I looked at 1961 again:
https://skunkwerkssuperstock.wordpre...thering-storm/
Another small oops, excusable for a Mopar guy I guess:
The 1961 409 was a single 4v, 360hp.
The top 1962 409 was the Beach Boys "4-speed dual quad positraction 409"
"409 409"
The song actually sings 409/409, inches and HP rating.
The 409/409hp-8v was the 1st DUAL quad 409.
In LATE 62, the 63 service parts (heads & cam IIRC) came out that actually made the 409/409-8v effectively a 409/425hp-8v, even though it kept its 409hp rating.
For 63-64, that same engine became the 409/425hp-8v.
So pretty much every 409 car you saw in 1960s class racing was a 1962 car, with a 409/425hp-8v under the hood (but rated at 1962's 409hp) or a 409/400hp-4v under the hood (but rated at 1962's 380hp)
Not as convoluted as all those Mopar combos (ever count how many 383/330hp engines Mopar had?????) but still complicated.
Of course the Beach Boys song features a real 409 soundtrack.
This is fun stuff, glad the Nostalgia Stock section has some life again.
Old 10-31-2021, 09:29 PM   #164
Rat Patrol
Rat Patrol's Avatar
Liked 32 Times in 27 Posts
Pretty sure the Antlocer car had a 4-speed manual trans, therefore couldn't have run in an auto class.
Here's a pic of the '61 that Hayden Proffitt drove @ Indy '61. It has both S/S & OS/S on it. I'm guessing that lots of racers back then referred to lots of classes as "Super Stock", & sorta lumped 'em all together, rather than callin 'em Top Stock & calling each class by it's specific designation. With this in mind, don't know exactly which specific Super Stock class Antlocer was saying he ran.
From my web site.
Rat Patrol is offline   Reply With Quote
Old 10-31-2021, 09:32 PM   #165
Rat Patrol
Rat Patrol's Avatar
"409 409"
Ive been advised by Raj Reddy who's a Chevy guru that Nicholson ran the dual quad set up, supplied by Chevrolet, at the 61 Nats..before it was commercially available..... hence it was in OS/S , not S/S.
“Mal - They received the dual quad setup and cam August 1961 prior to Indy ‘61 (placing them in OS/S) . Cars ran single four barrel 360 HP at ‘61 Pomona Winternats.“
Old 10-31-2021, 09:38 PM   #166
Rat Patrol
Rat Patrol's Avatar
Sorry, Ithought you were talking about the tables- not the text. I’ll fix it.
Old 10-31-2021, 09:41 PM   #167
DeuceCoupe
"...Is there any chance that Antlocer 61 Bubbletop on pg14 of Boyce maybe was R/U at 1961 Indy & not 1962 Indy?..."
I don't have a clue.
Maybe he was just mistaken about that RU finish.
https://www.hemmings.com/stories/200...agstrips-again
I just noticed this pic in the SS book. In the far lane of this 1st pic is the Myrtle Motors '67 Bird. Because of the way the A is written, I first thought it was marked A/SA. But, when I enlarged the pic, it actually looks to be H/SA.
That brings up the question:
Exactly which engine would a '67 Bird have to have, in order to run H/SA, back in the '60's ?
Since I have an old pic of a '67 400 RA Bird marked C/SA, I'd assume it would need to have a 326HO engine, to make H/SA. But, in the pic, the car has a 400 hood on it. Don't think a '67 400 RA Bird ever ran A class.
BUT, I do have at least 1 pic of Truman Fields '68 RA2 Bird marked A/S. But, that was in '72, which was one of the weird pure stock type years. So, I reckin it all depends on what year we are talkin about.
H/SA=
15.00 in 67
11.50 in 68
11.00 in 69
10.50 in 70-71
The 327/285hp 67 Bird has W/P=11.23 with Auto
So I'd guess 1969 H/SA=11.00 class
But then there's the 400 hood:
I dont see how a 67 Bird would fit in A/SA, ever, unless maybe in goofy 1972 when A/SA=9.00 class.
Then a 400 RA1 factored to 360hp would fit, W/P=9.01
Do you know what book/page that picture is from?
Old 10-31-2021, 09:50 PM   #168
oldskool
oldskool's Avatar
"...Do you know what book/page that picture is from?..."
SS book p.137
Here's a couple more pics from the SS book.
#1 is a '64 GTO which was running in the AHRA F2 B/S class.
#2 is the Royal '66 C/S GTO, which ran the quickest ET in C/S, @ the '66 Winter Nats, but got a DQ because NHRA hadn't OK'd the factory RA set-up.
Name:	1 - '64 F2 B-S .jpg
ID:	61056   Click image for larger version
Name:	2 - DQ @ '66 Winters .jpg
Old 10-31-2021, 10:57 PM   #169
DeuceCoupe
NHRA wisely started OS/S for that reason, too many "trunk & parts counter" combos coming out. The 390/401-6v Ford & 421/373-8v Pontiac got the same treatment, bumped into OS/S.
Very few 409s period were made in 1961, about 160 or so IIRC - let alone a dual quad version. Usually on the street it was the 348 Chevy that met the 390 Ford.
Was Nicholson the OS/S R/U at 61 Indy with that car or dont we know?
Old 10-31-2021, 11:17 PM   #170
DeuceCoupe
SS book p.137
OK found it, forgot about that color section.
Looks like that picture has to be 1967, the only year that Sox's RO23 car ran in SS/B=7.00-7.69 class.
That means that for the 67 Bird:
A/SA=8.70-9.49 and
H/SA=15.00-15.59 not likely. No 67 Bird even fits in there.
But if the Bird is in A/SA, what does that mean?
3244/325=9.98 unfactored, doesnt fit A/SA=8.70-9.49 class.
3244/360=9.01 if the RA1 was factored to the GTO's 360hp already.
That factoring to 360hp could put a RA1 Bird into A/SA=8.70-9.49 class in 1967.
OK, sounds good.
But it presents another problem:
Tony Knieper ran a 67 Bird RA1 in SS/FA=9.50 at 68 Pomona.
How'd he do THAT then?
Unless it wasnt run as a RA1 car.
A base car fits SS/FA=9.50
3244/325=9.98
But the link below says RA1.
If we use the above logic and factor the RA1 to 360hp then
3244/360=9.01
That bumps the Knieper car from SS/FA=9.50 to SS/EA=8.70 class, but it ran in SS/FA=9.50 class.
So it had to have an NHRA rating of way less than 360hp, like 340hp or less. Would the RA1 Bird be factored to 360hp in 1967, then DOWN to 340hp in 1968, then back UP to 360hp for late 1968? Sounds unlikely.
Unless it wasnt run as a RA1 when it was R/U in SS/FA=9.50 class at 68 Pomona?
Since you're a Pontiac guy, here's the link!
https://www.hotrodders.com/threads/6...holder.144313/
Confusing story. Any ideas?
